1987 Mantra repower and make over
Results 1 to 14 of 33
    Member Waterslinger's Avatar
    Merritt Island FL
    Default 1987 Mantra repower and make over
    Got a deal on this old girl but had to drive 500 miles to get it. Had a 454 but will have a 557 Ford soon. Doing the pump now. Kept the intake and installed my cav reducer and stainless AT imp., AT bowl, berk droop and new FTN place diverter.
ID:	677234   Click image for larger version.
ID:	677242   Click image for larger version.
ID:	677250   Click image for larger version.
ID:	677258   Click image for larger version.
    Merritt Island FL
    Note red neck imp nut socket looks like crap made from old exhaust pipe and cut up socket in the dark and in a hurry but she works great lol
ID:	677314   Click image for larger version.
ID:	677322   Click image for larger version.
ID:	677330   Click image for larger version.
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    big ford in a Gullwing!!!! My kind of set up! Nice.
    Senior Member brgrcru's Avatar
    Montrose
    You sure did a good job on taking that berk transom adapter off. Looks like it never was on there.
    I am with Nick big ford in a GW perfect
    Good luck on your build.
    Merritt Island FL
    Rails are in and steering is done, need fwd / rev cable and plumb trim cyl next.
ID:	677586   Click image for larger version.
    okie, lake Texoma
    Get a REAL steering extension. jmo.
    H8-2-W8
    [email protected] first pass
    Dec 2010
    Sapulpa ok
    Wouldn't be a bad idea !!
    Shell Knob, MO
    [quoteget a real steering extension. Jmo. ][/quote]
    x 2
    Oct 2011
    Sandia,Tx. 78383
    Good 'Ol redneck ingenuity...slack and pinion steering adapter ! Looks good ! But yea , better do it right
    http://oathkeepers.org
    Merritt Island FL
    That strange steering deal was on the boat bad part is I let a real one go with the old hull. Will turn one out in the shop or call HTP. The alt mount is the challenge now thinking upside down is the way as u can see the conventional mount would require a lot of material removal on the plate. Was thinking you guys may have some pics of clean set ups so i can R&D them. R&D = Rob and Duplicate lol
ID:	679994   Click image for larger version.
ID:	680002   Click image for larger version.
    okie, lake Texoma
    HTP has a nice little atlernator bracket that will get you out of that spot, might as well get the steering extension too.
    Half way down this page
    Hi-Tech Performance : Other Performance Parts
    H8-2-W8
    okie, lake Texoma
    ftw
    H8-2-W8
    Merritt Island FL
    Thats a Chevy set up need a Ford set up
    Merritt Island FL
    Drilled and taped the motor plate, cut down the spacer, flipped the alt upside down and bolted it up. Made a new stud to hold the plate and adjuster bracket.
ID:	680394   Click image for larger version.
ID:	680402   Click image for larger version.
