lexan splash shield
Results 1 to 5 of 5
lexan splash shield
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default lexan splash shield
    Where can you get a lexan splash shield for a TX19
    Member Waterslinger's Avatar
    Merritt Island FL
    We do lots of lexan work, you have a pic?
    Oct 2011
    Sandia,Tx. 78383
    We went to a Glass Company and ordered a sheet of smoked Lexan , made our own & split the costs between a couple of us . Cut out desired design and then bolted it in the center of the boat , took a heat gun , formed it around corners ...takes patience and a couple buddies to lay it in and clamp it down as you work it , but can be done in about an hour
    http://oathkeepers.org
    Try Finneys plastics in BHC Az or search for Wayne Earl company in Socal both may have suggestions they both were making Plexy shields and windshields
    Sep 2010
    Default thanks
