Wing placement on Daytona
Results 1 to 7 of 7
    Atlanta TX
    Default Wing placement on Daytona
    Need instructions on wing placement on a Daytona. ? Place straight edge across, forks & measure so many inches back & drill 1st hole ??? Holes go dead center of where hull top half & bottom overlap ?? Wing is carbon fiber. Appreciate any help.
    Rick
    corona calif
    Default Wing
    Quote Originally Posted by cpjet View Post
    Rick
    Who's wing is it?
    Atlanta TX
    Shoe sent you PM
    Atlanta TX
    Stark
    San Diego, CA
    I'd call him and get directions on where you should mount it. Each of the wings are a little different and require different mounting. Generally as far forward as you can on the boat. Typically the area where the top and the bottom hole meet at fairly thick. You'll need a nut cert tool.
    Boat 405.
    Atlanta TX
    Have the nut certs, tool , & bolts, just dont want to drill holes more than once & want it to be in correct spot
    Oct 2011
    Sandia,Tx. 78383
    CP , please post a pic when your done
    http://oathkeepers.org
