[Question] Jetting Size Input
Results 1 to 11 of 11
Jetting Size Input
    Member Rude Louie's Avatar
    Mar 2010
    Rocklin, CA
    Default Jetting Size Input
    I'm running a somewhat mild BBC 468 with a set of Holley 660's. Currently the jets are 78 primary and 82 secondary. Last time out, checked a plug and it was pretty lean. Also noticed on top end it had a bit of "surge" is the best way to describe it. Anyways, from experience, is it recommended to run them square or staggered like they are? And what size do you guys run? Thanks
    Senior Member Cheyenne321's Avatar
    Sep 2011
    Shawnee, OK.
    Just a thought. I would check for a vacuum leak around the manifold, may be an issue with the surging and lean plugs issue. Stray starter fluid around the gaskets while it is running and see if you notice any increase in RPM.
    Apr 2010
    Rocklin, Calif.
    Where is your fuel press. at?
    Mar 2010
    Rocklin, CA
    Quote Originally Posted by Cheyenne321 View Post
    I'll give it a shot, thanks
    7 1/2 to 8lbs
    Sep 2012
    I ran a set (660s) 468 motor, for several years factory jet size, plugs were always black,ran good at wot.
    Mar 2010
    Rocklin, CA
    I ran this same setup in my old boat without an issue. Maybe the "surge" that I'm feeling on top end is underwater hardware?
    Don't get me wrong the boat runs great! Just trying to do a fine tune
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by Rude Louie View Post
    There's nothing wrong with the hardware...I ran that set-up for years
    Sep 2012
    I have a box of jets i can bring Sunday if you want you try some rejetting.
    Apr 2010
    Rocklin, Calif.
    One thing he's not saying....it was 108" last time out..pretty much shitty no air
    Senior Member Orange-Gasm's Avatar
    Jul 2012
    Sanger Ca.
    Thats alot of pressure.
    I would'nt have to manage my anger if people could learn to manage thier stupidity
    Apr 2010
    Rocklin, Calif.
    Cool
    We lowered the fuel press. from 9lbs. to 7.5 ran real good all day....timing and jetting was good
