boat steams out of one pipe while hooked up to water on trailer
Results 1 to 9 of 9
    Feb 2013
    Default boat steams out of one pipe while hooked up to water on trailer
    im thinking of buying another boat , owner says it steams out of one pipe while on trailer, i know its a dumb question , but im thinking a head gasket , however owner says it has no milkshake in the pan , is this because it has blown between the cylinders and not the cylinder and water jacket ? boat has 150 orig hours on it
    Senior Member uniboarder's Avatar
    Dec 2012
    Is he just reving long enough on the trailer for water to get to only one header? Ask him what RPM does his T-valve open at and have him hold it there for a second.
    Quote Originally Posted by swtd19 View Post
    Running dry on the trailer when this happens or hooked to a hose ? , headers, thru hulls , more info might help ?
    Feb 2013
    the guy says its hooked to the hose runs a little rough tho , and no water in the oil
    , the boat has headers
    Sep 2011
    Los Angeles
    Your about to catch hell from the water hose police for running it with the pump engaged (if it is engaged) but there are a few factors.. Mine would only steam out of one at a low rpm but when you give it some gas they both would inject water. Could also be a clog in the Tee valve.. Just my .02
    Pull the plugs and check for stains or moisture signs, probably a plumbing issue , these boats rarley seem to develop head gasket issues
    Jan 2012
    St. Louis, MO
    Quote Originally Posted by larryfknrocks View Post
    water hose police
    LOL!
    Feb 2015
    Clocked water passage?
    Default Header temp?
    Check to see if one header is running hotter than the other. A "Temp gun" would be the best way, but just holding your hands close should also tell you if one side is hotter than the other. As Tom said, it's most likely a plumbing issue, those little feeder lines can, and do, get a little piece of shit in them.
    Check the header primary tubes for temp comparison... You can also check the "bleeder" holes on the bottom of the tubes near the heads... Are both sides dribbling??
    Good luck...
    Ray
    LOUD BOATS SAVE LIVES
