12 Volt operated air valves
Results 1 to 12 of 12
    San Diego, CA
    Default 12 Volt operated air valves
    I use these for operating the air bucket and could be used for the Pop off valve.
    Here is the part number for the version that has screw type connections so you can use your own wires. They sell another version that comes with a two wires on either side of the valve for pos and neg but the wire is really small. I like the version that is the screw termial type or other wise know as a DIN connector.
    MME-41PEE-D012
    12 volt, 1/8" NPT ports. Powered both ways.
    About $50 a piece, they charge a handling charge on each order so I usually order a few to offset the cost of handling
    Part# MME-41PEE-D012
    Here is a pic I found off the internet. Although the part number is incorrect on the picture. The Part number I provided above is correct.
    Here is a pic of the one with the wire attached. If you want to go that route.
    Again the part number is incorrect on the picture. For this version with wires the part number is Part# MME-41PEE-W012
    Boat 405.
    San Diego, CA
    Again guys were asking for these all the time. Order directly from Clippard.com
    Boat 405.
    San Diego, CA
    Bump
    Boat 405.
    San Diego, CA
    Bump
    Boat 405.
    Mar 2010
    Clarksville, TN
    Big Thanks to Kjell I set my valve and bucket up just like he told me and it works perfect everytime
    Senior Member buckjohnson's Avatar
    Aug 2009
    Biola CA
    You can get them from Festo or SMC
    Senior Member Futs's Avatar
    Orange CA, Big River
    Is this just for the pop off or are you using it for the fwd/rev bucket together?
    San Diego, CA
    I use one for each.
    Boat 405.
    I use one for each.
    The one I use for the fwd/rev only has one side with the electrical, what's the difference? I have a few of them that I bought for back ups in the old boat, but now with the new boat and a pop off trying to figure out which way to go.
    San Diego, CA
    You'll need the versions I listed above. The one with the one side electrical will only work for the fwd reverse bucket and not the pop off
    Boat 405.
    Mar 2010
    Clarksville, TN
    Futs I rigged mine just like Kjell told me to and it worked perfect all season
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    The 2 sol valve has to close one when the other opens.
    The only other option is go full pneumatic no electrical.
    QE 439 Twin Turbo
