Dump valves for pop off systems
Results 1 to 14 of 16
    San Diego, CA
    Default Dump valves for pop off systems
    Here is a valve that is commonly used for a Pop-off system. A quick dump valve, mounts inside the boat one end connects to the top fitting on the pop off valve and the other plugs into the 5/32 pressure line from the co2 tank. About $20
    McMaster-Carr
    Boat 405.
    Ralls Precision Machine Ballztech's Avatar
    Mar 2010
    Asco 12V Solenoid Air Valve
    • Port Size: 3/8" FNPT or 1/2" FNPT
    • Brass Construction
    • Normally Closed
    • 300 PSI Maximum Pressure
    • Optional Mounting Brackets Available
    SKUAsco-38-12
    I like this one for the pop off dump. Very easy to use and set up. $34.00 Asco 12v Solenoid Air Valve - Pro Performance
    San Diego, CA
    They both do the same thing, except the top one needs no electronics just air. The lower one needs 12 volt power. Both will work great. Just a preference. Thanks Andy
    Boat 405.
    Mar 2010
    Kjell, you are correct. Although, with the 12v operated dump valve you do not need to use the additional "shuttle valve" ( MME-41PEE-D012 ) to operate the dump. I have had a couple fail, they can be temperamental from time to time. I have never used that set up on my pop off due to this. I only use this part for the fwd/rvs control.
    San Diego, CA
    Cool, that will work too.
    Boat 405.
    Senior Member Sweet Pickle's Avatar
    Mar 2011
    Calimesa CA
    Andy do you rely on the water pressure to push the popoff piston up? If so what holds it down til you open the dump valve? My system is similar to Kjells and works good but always curious
    Mar 2010
    Quote Originally Posted by Sweet Pickle View Post
    Yes, intake pressure opens the valve. Co2 pressure keeps it shut. Its important to make sure you have NO leaks on the pressure side. As you can imagine, its such a small pressure vessel that even a very small leak will result in a intake leak going down the track. We have had good success with the solenoid dump set up. Its very easy to hook this up to your data system and get the valve to release pressure (allowing it to open) at a pre-set intake pressure level. We verify this with regulated co2 pressure. Works great.
    Mar 2011
    Calimesa CA
    So no reset until your back at the pits? Or do you apply CO2 pressure while in the driver seat?
    Mar 2010
    I usually will "bump" the fill button a couple times to seal the intake back up. I think it provides better water supply to the engine. Especially after ringing its neck for a 1/4 mile. I'm not sure if I'm helping anything by doing this but its what I do.
    Mar 2010
    Clarksville, TN
    Thanks for posting this guys. I'm in the process of rigging up my valve and could use all the info you could post 👍
    Mar 2011
    Calimesa CA
    10-4 Thanks for the info Andy
    149 Tsunami BGJ 153 MPH
    Dec 2014
    So Bay CA
    March 4, 2015
    Hello People
    That 6646K34 McMaster-Carr valve can be used in the popoff system without air pressure on the up stroke.
    The Quick release exhaust valve only needs positive pressure to set and when removed, the static pressure from the water will lift the popoff piston.
    You just have to make sure the intake / exhaust port at the bottom of the popoff is not in the water.
    Willis
    149 Tsunami - 153 MPH @ 6.93
    Mar 2010
    Clarksville, TN
    Hey guys i'm in the process of installing my Miersch valve in the boat and really starting from scratch .. Could yal do a parts list of what is needed on a valve install and a run down on how everything works ..
    thanks
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    thanks
    Mike...Call Roy Mierch.He is very helpful.
