jetaway gear oil?
Results 1 to 13 of 13
jetaway gear oil?
    Senior Member Cheyenne321's Avatar
    Sep 2011
    Shawnee, OK.
    Default jetaway gear oil?
    What type of gear oil is everyone using. Does it matter? Any old gear oil. I was thinking about Lucus Gear oil. I have some of Hi-tech oil too but was wondering about alternatives.
    Dec 2010
    Sapulpa ok
    I just use his stuff. It's cheap I keep several bottles if you ever need some.
    Sep 2011
    Shawnee, OK.
    Thanks I have some so I will see if it is enough. The gasket was leaking at the bottom. I am replacing it and was just curious about the different gear oils being run in them. Would seem that about any would work, I May be wrong, I will ask him and see. I need new gasket too.
    Member Blown94SKP's Avatar
    Apr 2011
    Mechanicsville VA.
    You might want to ask him about a oil feeder/reservoir that sits on top if your running up and down river all the time. Helps keep it out your bilge.
    Iuka, Mississippi 38852
    I`ve used 90 wt with just enough ATF poured in to give it a red tint for the past 8 years with no problem.
    Senior Member bp298's Avatar
    LHC
    Redline heavy shockproof gear oil...
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Quote Originally Posted by Richard Till View Post
    x2
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    San Diego, CA
    X2
    Boat 405.
    Mar 2010
    Clarksville, TN
    Same as Richard 90 wt with a shot of ATF fluid
    Sep 2011
    Shawnee, OK.
    Thanks for the information guys, I had enough of HTP's oil left but added a bit of Lucus oil additive into it. Got the leak fixed to so no more messy bilge.
    Mike are you still running the ratchet that was on the boat when you bought it from me?
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by Cheyenne321 View Post
    Ya, we rebuilt it but works great.
    Sep 2011
    Shawnee, OK.
    Cool, Rebuilt as in new gaskets or was it broken some how? Worked great last I remember, the only thing I noticed about it is if I made a long run down the lake for several miles it would get a little warm.
    Mar 2010
    Clarksville, TN
    Just replaced the springs, seals and gaskets.. Everything else looked great
