Recommended Intake Gaskets
Results 1 to 1 of 1
    Senior Member Gravyboat's Avatar
    Commieland
    Default Recommended Intake Gaskets
    for a Ford 460. It developed a pretty consistent external leak at the front water jacket. Tightened as much as possible but wouldn't go away. Just wondering what's best to replace them with. Or will any old Fel-Pros, Edelbrocks, Mr Gasket do from my local speed shop?
    Some details:
    Not a hot rod, just cruiser with a little extra HP
    Iron heads
    Performer RPM manifold
    Ports have some work. Measure about 2" W X 2.25" H
    It's a jet (obviously) so there's the concern for excess pressure pushing through which did happen when I first bought the boat 9 years ago. Since that incident, I installed a regulator and haven't had the problem again.
    From what I've been reading, the metal core gaskets are not best choice for marine applications. That's what I currently have. Victor Reinz jobs that don't match the ports very well.
    Freedom Without Authority is Anarchy.
    Authority Without Freedom is Tyranny
    “The trouble with socialism is that you eventually run out of other people's money”
    –Margaret Thatcher
