Lo Profile intake and Engine alignment
Results 1 to 14 of 22
    Oct 2011
    Sandia,Tx. 78383
    Default Lo Profile intake and Engine alignment
    Well thanks to Hass and others input on the inducer issue which turned into Greg S. twisting my arm and talking me into a MPD LoPro intake setup :-) How much is this gonna throw off my DL angle ? It's no big deal as I've got to install new motor rails but how much is it off from Original pump ?
    http://oathkeepers.org
    Senior Member copterzach's Avatar
    You working on your Liberator?
    Sent from my iPad
    Aggie Class of '97
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    It will change a bit. It will bring your jet closer to the motor for one. Also you will most likely have starter and oil foyer clearance issues. I have maybe 1/4 inch clearance from the top of e tunnel to my starter on my Southwind tunnel. Top mount starter and a remote oil filter most likely are in your future.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by jyeager View Post
    I have an mpd lo pro, stock location mini starter, and stock location k&n 2002 oil filter. plenty of clearance. I do have to lift the engine to change the starter, but that doesn't happen too often. ran the same setup in my sw with a lo pro too. no problem changing the oil filter.
    Senior Member bc18's Avatar
    Definitely makes life easier.
    Oct 2011
    Sandia,Tx. 78383
    Quote Originally Posted by bc18 View Post
    Picked up a System 1 remote cooler from LiquidDan , Olsen block oil cooler from a friend in east Tx , so oil is not an issue , run drain line from pan to bulkhead fitting at rear transom to drain
    and Yes Zach ....the Screamin Bitch is getting a total strip down , makeover and Heart Transplant
    LHC
    not suggesting it wouldn't. just that it's not essential just because it's a lo pro.
    Oct 2011
    Sandia,Tx. 78383
    BP ,
    I was looking into a mini starter already , like the MSD or Powermaster , there should be plenty of room for one of those shouldn't it ?
    Sure glad I haven't drilled my new motor rails yet !
    San Diego, CA
    Quote Originally Posted by Gopher711 View Post
    BP ,
    Top mount starter would make life easier. I've seen a few guys run a bottom mount mini starter in a tunnel with a low pro, just doesn't look very accessible in most applications.
    Boat 405.
    Oct 2011
    Sandia,Tx. 78383
    Well hopefully it won't give me any issues ! The Powermaster one in Competition Products catalog says its sealed and waterproof, probably the one I will get
    Senior Member Sweet Pickle's Avatar
    Mar 2011
    Calimesa CA
    MSD Starter is the best I've ever run. Been in one of our blown programs for 4 years. Cranks like a champ with only a little battery
    Oct 2011
    Sandia,Tx. 78383
    Yea I like the MSD product but said nothing about being waterproof or sealed
    LHC
    I installed a tilton super starter in the sw in '97. ran it until the end of 2010. never had one ounce of problem with it. last year, installed an msd. very happy with it so far.
    like kjell said, access isn't "easy", but it's not impossible. like I already mentioned, I need to lift the engine to change the starter. for a few years, that was happening more often than I like. may get another msd for back up...
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Ron Cook in Parker,AZ has a better starter for half the price.
