Stressed....Jetaway install
Results 1 to 14 of 27
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    Default Stressed....Jetaway install
    So, I know it would have been easier with the pump out of the boat but.......
    I got it done!! Then I got very drunk.......
    Shell Knob, MO
    Nice looking set up there.
    Sep 2009
    Concord, NC
    And now, my set up is a little bit safer
    Big thanks Duane!
    AKA JET BOAT DAVE NOT A JET's Avatar
    mount island NC
    How long did it take and what did you have to do going to be doing one soon
    DAVES NOT HEAR MAN
    Sep 2009
    Concord, NC
    Quote Originally Posted by NOT A JET View Post
    About 4hrs. If you can,pull the pump out and do it on a work bench. I hate to drill and tap anything let alone doing it in the boat. If I was smart, I should have pulled the motor back out so I could at least sit in the bilge and tackle it head on. Nope. I did it leaning over the transome, standing on my head.... When I ordered it from Hitech, Duane told me to bolt it up with 4 bolts and use the Jetaway housing as a templet for the 4 new holes. You could do the same thing with just the gasket but, I think its more accurate this way. You have to take the front bearing cover off (8 bolts and a c clip) to take the mounting bolts out. Get a long punch that will fit in the bolt holes to mark your spots on the pump. Then take the Jetaway back off. Drilling is the scary part for me. The only advice I can give is to take your time.
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    Nice work and nice looking set up! I am a fan of orange powder coat too
    Sep 2009
    Concord, NC
    Installed Pics and a few other winter upgrades. Gas tank and vac pump. Just waiting on my drive shaft.
ID:	703234   Click image for larger version.
ID:	703130   Click image for larger version.
ID:	703138   Click image for larger version.
    Apr 2010
    Yakima, Washington
    BadAss
    Apr 2010
    Rocklin, Calif.
    Very Nice!!!
    Sep 2009
    Concord, NC
    Worried.....So got my new drive line installed. Got about 5/8 gap from the end of the splicer to the c clip on the Jetaway spline. Is this too much?
    okie, lake Texoma
    Quote Originally Posted by Jetdream'n View Post
    That's not a lot of engagement. , I believe you need to be about 1/8" from the snap ring.
    H8-2-W8
    [email protected] first pass
    Senior Member bp298's Avatar
    LHC
    yup. 1/8-3/16. otherwise, you can tear that thing up...
    Sep 2009
    Concord, NC
    Any Suggestion? Is there such a thing as a thicker PTO? Or some kind of spacer? Don't really want to have to have the drive line lengthened for a 1/2"...
    Oct 2011
    Sandia,Tx. 78383
    Have u Tried Viagra ? When My shaft needs an extra 1/2" ..it works for me
    'd get it redone , better than tearing up a high dollar Jetaway
    http://oathkeepers.org
