removingf stearing wheel and column
Results 1 to 13 of 13
    Charlotte, NC.
    Default removingf stearing wheel and column
    So im pullin all my wires to redo it all and notice that my steering wheel looka like CRAP. So should be easy enough to replace... Except removing this dang cover over the shaft.. any thoughts on how i remove this? Knowing my luck i will most likely have to toss the whole damn thing but thought i would ask.. thanks!!!
    To clarify.. the plastic peice looks like it unbolts from the back, I was more curious about the metal peice in front of it..... Looking closer at that pic i think a steering wheel puller will yank it off but i want your opinion first.. Thanks again.
    El Cajon, CA.
    The steering wheel adaptor removes with a steering wheel removal tool, the plastic piece behind you just grab with your hand and squeeze it and it will unlock from it's counterpart.
    Newton Ks.
    Yep. The adapter should pop off with either a puller or a good whack on the end of the shaft. It's "stuck" on a tapered shaft not unlike a tapered ball-joint shaft.
    Yep, the plastic ring just pops off the backing plate.
    H.L. Mencken
    Sean, most Autozones, Oreillys etc have a tool-loan program , maybe give em a Shout ? Tom
    Yucaipa, California
    I was able to finnagle *spelling* mine off without a puller..then afterwards..i found the puller the next day. Gotta clean mygarage!
    1992 Eliminator Daytona 21'
    Charlotte, NC.
    puller from auto zone worked. popped right off...
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    Depending on your steering wheel,Rex marine has these style adapters.
    Sean heres a Steering and dash were just finishing on a partial resto , a little inspiration for ya Tom
    before
    after
    Charlotte, NC.
    so new wheel is on the way.. However i was a dumb ass and have some how lost the key for the shaft.. Any thoughts on how to make one? or does any one know where i can get one or have one they are willing to let go of?
    Shell Knob, MO
    It's just a Woodruff key. Any local hardware store should have one.
    A decent hardware store or auto parts supply should be able to help you with that.
    Charlotte, NC.
    Kewl... thanks..
    Senior Member lbhsbz's Avatar
    Long Beach
    Sometimes you can get away with using your hand to pull like hell on the adapter and then give the shaft are good sharp rap with a hammer to unseat the taper. just make sure that when you do this, you leave the nut on the shaft so you don't garf up the threads.
    As for your woodruff key, even home depot should have them. just measure the width of the slot before you go.
    In a pinch, I've made woodruff keys out of old headbolt washers before.
