calgo tiller arm ?
Results 1 to 10 of 10
calgo tiller arm ?
    Diamond Bar, Big River
    Default calgo tiller arm ?
    Anybody have a picture of the calgo tiller arm used with a place diverter? I have a tiller arm that is gull shaped and am concerned it won't work with a place diverter type control. I assume there is a clearance issue between the width of the t. arm and the hyd. ram actuator bracket. thx
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Tim at place Diverter can hook you up with the right onez???
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    Jan 2013
    Magic Mountain CA
    Mine's manual and this is the same as the hydraulic arm only the hole was drilled round by Tim before he sent it to me.
ID:	705953   Click image for larger version.
    Senior Member bp298's Avatar
    LHC
    you should have a stop on that shift arm...
    Thanks for the pic. 74 Bonneville very helpful. I like those rod ends that the cables attach to, do they come with the tiller arm too from Place or did you source those elsewhere? Nice set up. Looks like I'll be givin Tim a call next week.
    Jan 2013
    Magic Mountain CA
    Quote Originally Posted by jetjunky View Post
    Tiller arm only at Place, you can ask him what else he has. The ends I have came with the boat when I bought it, I did buy some new tie rod ends from McMaster-Carr.
    Jan 2013
    Magic Mountain CA
    Curious why I need a stop. My manual handle sets in a notch where I want it at the time. I've read a lot of your posts and respect your opinion. Keep in mind my funds for this are very limited right now. Wife unemployed and kid in college. I buy what I have too, not what I want.
    Senior Member bc18's Avatar
    Quote Originally Posted by 74Bonneville View Post
    When the handle is in any notch go to the back of the boat and pull the nozzle up then down and see how much slop there is. That slop is actually a lot when you break it down. Putting a stop on the arm is a good idea and its not expensive. If you have some type of fabrication skills you can build one for under 20 bucks.
    Jan 2013
    Magic Mountain CA
    Quote Originally Posted by bc18 View Post
    Thanks BC, I hand made my 2 pump braces so I do have some skills. I need a picture. I'll do a little searching and see what I come up with.
    LHC
    look through this thread. willis posted a pic of his stop. http://www.performanceboats.com/jet-...quirement.html
    I don't know how much power/speed you have in your boat. the thing is, that tiller arm has great horizontal strength. not so great vertical strength, especially that upper p/d tab. for example, -if- you are at wot and the bucket is partially closed, it places a tremendous amount of pressure against the inside/top of the nozzle, which tries to force the nozzle in an upward direction. and that little tab will bend down like a spaghetti noodle, allowing that nozzle to rise to wherever it is physically stopped. if that is too much up angle for the boat to handle, very bad things could possibly happen. a stop, similar to the one in willis' picture, will prevent the nozzle from rising any further than where it is set.
