Cam question
Results 1 to 7 of 7
Cam question
    Senior Member NO BUTT NO PUTT's Avatar
    Santee, CA
    Default Cam question
    I have a 468 with closed chamber heads. I had a 292H10 cam and im going to try and fit a 288AR10 full roller cam. Think it will clear the pistons?
    Senior Member CK7684's Avatar
    Minnesota
    If you have to ask, then you better check...better safe than sorry
    Santee, CA
    Im checking it after work at a buddys house. Just wanted to see some thoughts.
    Tri-Cities, TN
    I will have to be checked along with installing springs to handle the roller. If these are OEM heads you might have to have the valve guides cut down for 2 reasons: Accept PC seals that will fit inside an inner spring and make shure there is enough clearance between the bottom of the retainer and top of the valveguide.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Santee, CA
    Well it fits, .175 clearance.
    Im going full roller. No more worring about cams.
    Razor Wire Militia 髯岙喢殮作's Avatar
    Lake Havasu, AZ
    Quote Originally Posted by NO BUTT NO PUTT View Post
    did you do what Chris told you to do???? or you will be worring about a cam again...
    Santee, CA
    Quote Originally Posted by 髯岙喢殮作 View Post
    Sure did, and it already has PC seals in it, along with some good head work.
