bowl ???
Results 1 to 14 of 14
bowl ???
    RLP
    RLP is offline
    Default bowl ???
    say ya have a570 lbs hull with 675 hp
    use for lake hot rod and some friendly drag race sometime
    what bowl would be ya choice for a berk pump?
    Okmulgee Okla.
    I put a "G" on an E intake with loader droop and place diverter works good on 75 Taylor SJ
    We recommend Dominator over 500 hp ..
    http://www.jetboatperformance.biz/pa...lit_bowls.html
    Senior Member 1975DiMarco490ci's Avatar
    Glendale (AZ)
    Exclamation
    sexy time!
    WILL KILL FOR A GULLWING.
    RLP
    RLP is offline
    click on the link and shows the AMT bowl are they the same as the dominator?
    Spiral out MikeF's Avatar
    What bowl do you have now?
    RLP
    RLP is offline
    Quote Originally Posted by MikeF View Post
    berk G that has some blend work and the frount side veins shaped like the AMT. almost seems like the work on it killed the take off
    RLP the biggest difference (AT vs Dom ) with the bowls is wall thickness (strength) and OD measurement , the A/T bowl is a direct replacement bowl for Berk etc the Dom/Berk replacement works with setbacks or modified transom adapters Tom
    Where are the pictures of the work done to your bowl?
    x2 I'd be curious to see as well ?
    RLP
    RLP is offline
    would have to take it off to get pics
    was not done by a rookie tho.
    just was wanting to see what the bowl of choice was
    Which pro was it?
    Can't imagine what was done to damage your holeshot?
    The Berkeley bowl is fine for you application, no real "need" for any other.
    Quote Originally Posted by RLP View Post
    an inducer might help the boat leave better.
    RLP
    RLP is offline
    has the DPS inducer
