Small block
Results 1 to 14 of 27
Small block
    Default Small block
    How will an 18' jet boat run with a Stock 350 Small block chevy? I am not looking to break any speed records. Just curious what to expect. Thanks
    Just a WAG..... 50mph. Twin turbo that bitch, then she'll really move.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Charlotte, NC.
    I run one in my 18 sleek craft. Its fun on the lake with freinds.. She wont win any races but its a lot of fun.. As its my first boat period i also think its a nice place to start before getting into a big block.
    Yucaipa, California
    good friend of mine has been running a stock 327 in his 18' hallet jet for years and years, thing goes all day long 50 mph wot. Even runs good with a boat full of fat asses, and a quadrajet.
    1992 Eliminator Daytona 21'
    Senior Member 1975DiMarco490ci's Avatar
    Glendale (AZ)
    friend has a 19ft charger with a 350 and a jacuzzi pump topped out at 43.0 with 3 people. with the impeller jacked up
    WILL KILL FOR A GULLWING.
    Senior Member gregb's Avatar
    Redondo
    I got about 62 out of mine (18 footer), had a comp cam, sportsman heads, performer rpm intake, and a 750DP. Not sure about the impeller, think it was a B cut, running about 4800 rpms. When it was stock with the Q-jet it would do 55 downriver on a good day at 4500 rpm. Lot of fun, ran all day on one tank pulling people, screwing around, and reliable as old yeller. Replaced it last year with a 383 SBC, turned and A impeller 5K and went 70 as it was burning up a rocker arm, haven't had it out since, replaced all the rockers and had the impeller cut and detailed, just waiting for a day to mess around with it.
    Bouncing off rocks TryMe's Avatar
    Sep 2008
    St Louis
    i only have a 15' boat, but with about 325hp, C impellor, it would run 65mph at 5400rpm.
    Thanks alot. It is my first jet boat. I have not had it out yet because everything around here in ohio is frozen. I can already see it it going to be addictive. And I can see a bigger motor in the future.
    Newton Ks.
    Quote Originally Posted by ttshock View Post
    "Morehorsepoweritis".
    A terrible disease.
    H.L. Mencken
    never underestimate the power of a small block! With the right heads and cam it is amazing the power that can be produced. They do however lack a pinch in the torque area. Do your'e self a favor and spend the money in the right spots and blow people away. you are already light so forget the 1k on aluminum heads and track down a good set of 492 angle plug iron heads. Have those worked and a good cam with a 750 carb and you are dancing in the 400 h/p range. I had a 19 ft daytona mini daycruiser with a good combo and ran 5k and estimated 55 mph and was a great boat, tons of fun and ran on a tank of gas all day long!! IMLOA Mark
    Rancho Cordova. CA
    I have a 406ci small block in my 1972 Elcamino drag car that can shove all
    3800lbs of it down the track doing 11.33 @ 120mph on the 1/4 mile. It is a 13 to 1 full roller motor with Dart heads and a tunnel ram. DT dyno says
    600 horse. It would make a fun ride in a small boat!!
    Morgan Hill
    Small blocks are cool, cheap HP, the thing you have to remember is you can't run it like a big block, you need the advantage of some rpm.
    We have run a 355 SBC in an aluminum hull with a BC impellered Dominator and ran 70 MPH all day long, but at 5900 RPM, so oil cooler, big pan, big exhaust, and open plenum hogged out intake with a good carb. are a must.
    A small block will run forever at 6K as long as its built for it. Make sure to get a good quality rev. limiter.
    GT
    GT
    Not a bad choice , you'lll have alot of fun ,like Old guy said don't underestimate the small motors ! Tom
    * heres a pair we built ,one sbf one sbc both run just under 80 ,finishing up another right now ,I'll post up pics soon ,call, post or PM if you need help
    Quote Originally Posted by carreradude View Post
    Congrats! An all steel 72 is not a light car! I built a 1978 street and daily driver that would click a mid 13 and drive home. Like I said "never underestimate" the small block! With or with-out the long arm. M
