Mounting Seats
Results 1 to 9 of 9
Mounting Seats
    Sep 2013
    Default Mounting Seats
    Guys, I have a 78 Taylor SJ and the seats have never been properly mounted since i've had it. Without removing the floor and doing it right, what alternative do I have to half a$$ it for the season? Really don't want to start that type of project now but would like to make it through the season without ending up in the back seat at WOT lol
    Jan 2013
    Magic Mountain CA
    Don't know what it looks like. I built small wood deck the size of the seat then on the side screwed a 2x4 sideways to sit next to stringer then a right angle piece of aluminum on the inside of the stringer then drilled the stringer twice for some long bolts then some fiberglass and resin to make it water proof and it was cheap and solid. First thought was 2x4's on each side of stringer, but would need 8" bolts to reach.
    Did you get that cause I'm not sure I did
    Quote Originally Posted by Sweat View Post
    We recently built "false stringers" in one of my 1/4 stringer boats for a similar reason using aluminum angle and clear fir heres some pics
    Jun 2014
    the oil extractor hose is cool
    Quote Originally Posted by ERV JR View Post
    So is the device this one will suck the chrome off a trailer ball, kinda spendy but worth it
    Jun 2014
    Got one also
    Senior Member Mouzer's Avatar
    corona ca
    VERY NICE TOM.................................
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
    Sep 2013
    Thanks for the advice, guys
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    I would use the side seat bolts only for the front seats, they will get you threw the season, back seat bolts to stringer with angle and the side, front seats have one bolt in the side and two lags in the floor
