Engine trying to die after hard pull
Results 1 to 14 of 19
    Sep 2013
    Default Engine trying to die after hard pull
    I just installed an Aeromotive electric fuel pump for mySJ. Pump is rated for over a 1000 HP. It's on a 505 BBC with a 1050 Proformcarb (1/2" line). I have it regulated down to 8 PSI. I think the motormakes around 600 to 630 HP. Coming in to the dock, I ran it 4k for a few minsand went to around 5800 for a few sec's and let out all the way to an idle.Fuel pressure was at 6 PSI right after the pull but at idle it wanted to dieand I had to throttle it up a few times to get it to recover. Then when I wasloading it on the trailer, same thing; nothing else has changed and I put newplugs in over the winter.
    I will say that I will never run a mechanical pump on any boat I ever have again. After setting for a few weeks, it's nice to turn the key on and prime the system, pat the gas twice and your off. Beats the heck out of turnig it over and over again.
    What should I do? Less fuel pressure? More fuel pressure? What are you guysrunning?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    If it wants to die at idle after being under power it could be several things. More than likely needs more air.
    Also to make sure a carb has plenty of fuel you can set the idle pressure to 7psi or so and give 12 -15 psi when under power.
    QE 439 Twin Turbo
    Sep 2013
    I think air is the problem too. I have the idle at 1100 now. Do you think I should Idle it up to 1200 or adjust the air screws?
    It still had 6lbs so I don't think fuel is the problem. Also, my regulator is the one shot deal. It can only be set to a certain psi at a time.
    Apr 2010
    Rocklin, Calif.
    Shoot a little carb clean through the air bleeds..it doesn't take much to clog them
    Checking the air bleeds is a good thing to do.
    Even a small bug can get sucked into them and typically, the air bleeds never get checked.
    If that's the case, you can usually see it with a good light.
    Are you using a mechanical advance in the distributor? If so, they can get sticky and cause a similar problem.
    Sep 2013
    It's an MSD Pro-Billet without mechanical advance.
    Sep 2013
    Can someone show me the location of the air bleed? Is it the four air screws that are on the side of the carb, on each barrel?
    Jun 2014
    you could have a piece of junk in the needle and seat. If its hanging the needle open it will run like crapand not idle. Do a test turn your pump on with the spark arrestor off and look down the carb and see if fuel is coming out the boosters. If so pull the needle and seat out. If you just put the pump on then I assume you made new lines, if you used an fittings and hose you could have a piece of the rubber from cutting in the N&S
    New Port Richey, FL
    Quote Originally Posted by Sweat View Post
    If you are idling that high then you need to check the position of the throttle blades and the transition slot. When viewed from the bottom the slot should look like a square. If the blades are open too far you need to let air in some other way. This basic setup needs done before going any farther.
    Float levels checked also
    QE 439 Twin Turbo
    Jul 2010
    CAMDENTON MO
    Default dominator
    air bleeds
    Senior Member spectralen's Avatar
    Aug 2009
    Mi.
    Vacuum gauge helped find my similar issue.
    Mar 2010
    Clarksville, TN
    How can you do that Ron with a regulator ??
    New Port Richey, FL
    You use a bypass regulator with a jet in the valve.. That should always be the regulator to use anyway. BG makes one with a jet in the valve itself. You set the idle pressure with the jet and running pressure with the valve. You can also use an enderle valve to do this.
    There are mechanical valves also that do this. Connected to the throttle linkage.
    The reason pressure is so low on a carb is so the needle and seat are not overpowered and flood at idle. Once it's running and making some power the needle and seat are open and flowing fuel. You can up the pressure while running and flowing fuel
    QE 439 Twin Turbo
    Mar 2010
    Clarksville, TN
    Thanks for the info Info
