youngblood
Results 1 to 11 of 11
youngblood
    Default youngblood
    Hey guys i dont know much about jet boats i am a v-drive guy but i have a tx19 youngblood i was wondering the difference between the jbx and the jbn hulls i have had a few people ask me about that, i know the boat is very light not real sure its going to make a good lake boat but what the hell
    Q.C./Big River
    Quote Originally Posted by matt wheeler View Post
    How light is it? anything over 500lbs should be OK for a lake boat. There is really no difference between the two. Only minor changes. The bottoms are the same. Check out this site.
    http://www.youngbloodjetboats.com/
    Default Youngblood
    Its lighter than that i would say around 400 to 450 me and my girlfriend took the boat of the trailer and put it on a dolly by ourselves
    Q.C./Big River
    can you walk on the deck without it making any creaking noise from it flexing? How much does it flex when you step on it, if you can without it breaking? How much does the boat flex if you lift up on one of the rear corners/transom? If it is a really light boat you will want to be careful while on the lake. If you hit choppy water or a big enough roller it can cause some serious damage not to mention if it crack or breaks it could sink. If it does flex a lot and you really want to keep this boat then you should take it to a good glass shop and have them reinforce it with core mat or even coremat and balsa. There seem to be many really light gullwings in the Midwest.
    Default youngblood
    you cant even walk on the deck if you touch it with your hands it will flex if you get on the sides of it you see the floor moving
    Senior Member hotbo's Avatar
    lake Ouachita AR
    jbn made some 350lbs to 375lb hulls i have 1 of them im going to build sounds just like your hull.mine is a jbn original jim youngblood hull.
    the difference if you look is all in the top cap,my brother has a jbx jimmy johnson hull outta vian oklahoma and the top cap is totally different.more rounded and arched up.the jbn top caps are alot flatter out front.other than that not alot of difference.hope this helps.travis
    El Cajon, CA.
    This thread is useless without pictures.
    Thanks for your help
    Q.C./Big River
    If that is the case then I would definately be very cautious out on the lake. It sounds like it might weigh around 350 lbs. I have seen many like what you are describing and I had no problem lifting it off the trailer by myself. It will be fine, and fast, but just watch where you are going. If the water is choppy don't put it in the water. Just my opinion!
    Q.C./Big River
    Default Another Question
    Does it have an all fiberglass transom or is there plywood in there??? That will tell you a lot about the lay up.
    Default youngblood
    its plywood
