Steam from breather caps? Help
Results 1 to 5 of 5
    Dec 2014
    Default Steam from breather caps? Help
    Freshly rebuilt ford 460. Completely new internals new gaskets, new everything. Got some steam coming out of the breather caps ( no pcv) No milky residue on the dip stick or underside of the breather caps. Is this normal? Like I said it's not a lot, just some.
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Probably just condensation. Keep an eye out on the oil
    Tower Park Resort, Lodi, CA
    Quote Originally Posted by Blaster5337 View Post
    yes
    Likely the engine oil getting hot enough to cook some inherent moisture out of your crankcase , if the oils not milky wouldn't worry
    Feb 2015
    Default Steam
    Add some Marvel Mystery oil to the crank case,Its a mystery how it works,,,
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
