Wet or Dry ???
Results 1 to 9 of 9
Wet or Dry ???
    Senior Member xxtremez's Avatar
    Jul 2013
    Texas
    Default Wet or Dry ???
    Im trying to decide to run wet or dry headers. My previous rig had a wet set up with billet control valve at my seat. I have the option to get a set of SS headers and run them dry. My other option is Bassetts or have a set of mild steel made and run them wet. My new boat has a larger cam than my previous boat and I have some concern of milking down the oil. I never had an issue before but have heard it can become an issue with larger cams. This is a lake boat that I will grudge race with, not a strict race boat.
    Thanks in advance
    Fo Show
    Senior Member Nosjunkie's Avatar
    May 2010
    Rough and Ready CA.
    Dry jethot coated headers... jmo...
    We could not get away with them dry in cali due to the lake nazis....
    LIVE FREE OR DIE
    Tacoma Wa
    Dry headers are hot as hell. I run injected in mine to keep em cooler and quieter. My cam has a lot of reversion so I modified my feed lines a bit. I look my water lines and plumbed the inlet with a pipe thread for a 1/4 or 3/8's pipe of plug. Been so long now I can't remember. The. I drilled the center of the pipe plug so it was kinda like a jet.
    Have never milked an engine with this setup, and the headers run cool and not too loud. They only omit a most the of steam when under away and they go dry at idle with the spring valve.
    Jan 2013
    Magic Mountain CA
    Quote Originally Posted by xxtremez View Post
    Thanks in advance
    I plumbed my exhaust water to a ball valve at my seat so I have control of the water flow. It's easy to do and doesn't cost much at all.
    Mar 2010
    Clarksville, TN
    I wouldn't run dry headers in my lake boat, there hot as hell
    I don't feel its too bad, i run dry headers in 110* heat.
    Dry headers that are Ceramic coated cool down much faster than Chrome headers that are run wet. They also don't rust.
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    I ran wet ceramic coated with basset spring and very little water, just enough to keep them cool because dam they got hot if you sat in the back. Think I set it up so water didn't come out till around 2800-3000 rpms, never seemed to kill power plus it kept the dam Cali fuzz off my ass because I never ran baffles.
    Sent from my RM-917_nam_usa_214 using Tapatalk
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    If you can handle the noises, heat and the cost$$$, dry SS is the way to go... I dig the goldish color the turn too😎
