Plumbing water to heads first?
Results 1 to 5 of 5
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    Default Plumbing water to heads first?
    I was thinking of a better way to help with detonation, am re-plumbing boat right now, someone suggested routing water into heads first then out of the front of block, any pros or cons to this. Oh its on a ford 460 11:1 compression with lightening headers.
    Sent from my RM-917_nam_usa_214 using Tapatalk
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Iuka, Mississippi 38852
    Great idea if you don`t want to keep the engine full of water and quickly destroy it. That bandaid won`t work.
    Dec 2010
    Sapulpa ok
    I did it years ago when we were running a blown gas deal. No problems but it was a BBC.
    Dec 2009
    Sac, Ca
    Why would it destroy it?
    My only boat since 1975
    Torrance, CA
    Air rises to the top. Unless you make some provision for constant air bleeds off the top of the heads, the block/heads may not be full of water and air-pocket free when filled from the top, and exit is at the bottom.
    I understand the impetuous for trying this (reducing detonation), but the old-school way works. I'd stick with it, and not reinvent the wheel.
