What Battery Are You Running?
Results 1 to 14 of 24
    Member sideways_s13's Avatar
    Dec 2012
    Hermann, MO
    Default What Battery Are You Running?
    I'm rigging my 16ft Hondo and I've hit a small snag. The "marine" battery that I've run in my last hull is kind of bulky. The Hondo is a little more cramped than the hulls Ive ran in the past. I want to build a mount to place the battery on top of the stringer near the transom. The battery I have now is too big and bulky. So long story short what battery is everyone running? Specifically any compact sizes? There will be no unnecessary electrical components in this boat ie radio/sound system. I know batteries aren't cheap.. what isn't though.. I'm ok with spending for something like an Optima but is there anything out there that's a little less pricey to look at first? Summers right around the corner and I need to get this thing rigged asap
    '73 Hondo Jet, 5.3LS, Borg Warner S475 "MACHINIST MAKE THE WORLD GO ROUND"
    Apr 2012
    I know you said you're low of real estate in there but I run dual blue top Optimas. Run them in my offroad truck too, they will hold a charge all winter as long as you have a battery cutoff switch in place.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    Quote Originally Posted by sideways_s13 View Post
    Same deal here, i went with an Odyssey and wouldn't look back.
    Aug 2013
    im trying a braille they are the lightest batterie on the market you can flip them any way you want they are small they have more cranking amps than any thing out there for the size 1350 cca they use them in trophy trucks, nascar are a dry cell and have a killer reserve ohh did i mention its only 21 #
    tease me
    Two 29 Maxx marine...
    Made In The Shade
    Custom Window Tinting
    bullhead city
    x2 optima
    Dec 2012
    Hermann, MO
    Thanks guys for the responses.
    Quote Originally Posted by tease me View Post
    Wow those Braille batteries are badass! 1350cca is nuts! That might be overkill lol. I'm going to pick one up. Im only spinning over a 5.3LS do you think this would get the job done? https://www.braillebattery.com/index...atteries/b2015
    Senior Member racerick784's Avatar
    Jan 2012
    ROSEVILLE CA.
    Default Battery
    I had an Optima Blue top last over 9 years. Do not let them discharge all the way. They can charge with a regular battery charger but if they discharge all the way. They need a AGM Charger. Good Luck, RACERICK
    Senior Member badbug3's Avatar
    I have this battery for sale with custom peterson battery mount. Mounts on side of stringer. Its 4 years old. I bought a lithium battery at stupid price and had to make another battery holder to fit so dont need this one. I paid $150 for this battery. It still checks good . I will take $100 for the battery and mount if interested. Battery weighs 15 lbs.
ID:	730585   Click image for larger version.
    Total seal or Odessey batteries are the best, then optima. On a budget look at U1 or U33 or lots of other similar numbers batteries. They are 33 amp hour wheel chair/lawn/gargen/security system/gate opener batteries. They are small and light. Completely sealed like a Optima, mount in any orientation.
    Funco (high end sand cars) used to use Interstates version of them in their buggies from subaru to V8. They work well. Had one in my subaru sand car. Interstate changed manufacturing and the quality took a dive. However their are lots of buggy vendors selling similar batteries and I haven't heard of quality issues.
    The smaller battery will be fine in your application as long as you use a permanent magnet gear reduction starter, aka Hi-Torque or OEM from about the mid 90's. Don't use an old chevy starter they pulled tons of amps because the electricity activated the magnets and they are direct drive.
    These batteries don't list a cranking amps, but I found this spec: 495 amps at 77 degrees Fahrenheit, like I've witnessed these batteries starting LS V8's stock and modified all weekend no problems.
    Weight = 24 lbs
    Height = 7.1 in
    Length = 7.7 in
    Wdith = 5.2 in
    Use a desulfating maintenance charger. like the pulse tech, XC 100-P in amazon for $79. It keeps the battery topped off ready for use and the pulses break down sulfate build up. The one i bought has saved two batteries so far working on 3 an 4.
    Aug 2013
    Thanks guys for the responses. Wow those Braille batteries are badass! 1350cca is nuts! That might be overkill lol. I'm going to pick one up. Im only spinning over a 5.3LS do you think this would get the job done? https://www.braillebattery.com/index...atteries/b2015
    i was going to by the odesseey wich is a bad ass batterie but the brail surpasses it by alot so i got the braille supper small and supper light
    tease me
    Tacoma Wa
    I run a single optima red. Have two seasons on it. When the boat is sitting battery is not hooked up and on a trickle charger.
    San Diego, CA
    Braille. I've had three Odysseys' just die. Go from working great to dead the next key turn 5 minutes later. The Braille stuff I've been running for about 4 years now with zero problems.
    Boat 405.
    Feb 2010
    Agree with widowmaker. Tried an odyssey and got less than 2 seasons out of it before it died. Been running a braille 3121 for 4 seasons now and it is still going strong.
