NJBA Changes 2015 Safety rules for Speeding and Setting Records
Results 1 to 10 of 10
    149 Tsunami BGJ 153 MPH
    Dec 2014
    So Bay CA
    Default NJBA Changes 2015 Safety rules for Speeding and Setting Records
    May 15, 2015
    Hello People
    The NJBA has changed how the ET and MPH are set.
    The ONE TIME over the speed limit used to set the records is now disallowed. There are more undesirable penalties too, check it out at the Schedule, Points & Results
    Willis
    149 Tsunami - 153 MPH @ 6.93
    Senior Member bp298's Avatar
    LHC
    good moves. glad to see it...
    Senior Member Red Rocket's Avatar
    winchester, ca
    Just checking but did you notice the other changes Willis? Not the penalties but the course change.
    Dec 2014
    So Bay CA
    Quote Originally Posted by Red Rocket View Post
    Yes,
    Will talk to you at the track
    Willis
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Good decision IMHO to go 1000'.
    1/4 mile records are a done deal looks like.
    QE 439 Twin Turbo
    Senior Member PE 340's Avatar
    Aug 2013
    LHC,AZ
    In the past 1000 Ft MPH times have been labeled inaccurate.
    Is this still the case.
    San Diego, CA
    Quote Originally Posted by PE 340 View Post
    The 1000 ft course has it's own time trap between 900 and 1000 feet which is turned off during a 1320 run.
    Boat 405.
    Aug 2013
    LHC,AZ
    Then,Why were they recorded by Duane Simms in the past when left ON and called inaccurate ?
    winchester, ca
    Have you not paid attention to the previous threads and discussions about this?
    The speed traps are finish line only. One set at 1320 for 1/4 mile classes, the other at 1000' for 1000' classes
    The 1000' set is not active on 1/4 mile runs. The timing system
    gives estimated speeds at the 660' on all runs and 1000' estimated speed on 1/4 mile runs.
    Aug 2013
    LHC,AZ
    Thanks Mike.Don't recall previous threads.
