Epoxy
Results 1 to 12 of 12
Epoxy
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Epoxy
    So i'm trying to clean up my intake, getting off the old epoxy is a bitch... any of you guys have any tricks? So far whats been working best for me is a air hammer and then hitting the small stuff with wire wheel.
    add a little heat to it with a propane torch. I prefer the 2 inch 36 grit sanding disk on a right angle die grinder.
    Morgan Hill
    Check these out!, Work bitchen...Warm it up a little with a heat gun or Turbo torch (propane) and hit it with one of these (clean in about 20 min.)
    http://www.amazon.com/dp/B000LQLGHY/...0&linkCode=asn
    GT
    GT
    Choking my ....... beerjet's Avatar
    Rancho Cucamonga
    Your more than welcome to my prybar
    Love aint nothing but a four letter word, just like f*ck and sh!t .
    Use a 90* die grinder with a red or brown rol loc disk. It will take to 10 mins If your still stuck Shaun, shoot me a pm with your number and Ill walk you thought it
    Mike
    G H E T T O F O E L I F E
    Ladera Ranch
    I use a 4 inch angle grinder with an 80 grit disc on it. Takes a few minutes and as long as you are careful you wont have any trouble
    So Cal
    Been there done that ... angle grinder it, wash it, blast it, machine it, power coat it, install it:
    Quote Originally Posted by BUSBY View Post
    All that work and it never even got used Your new intake is the bomb Busby
    So Cal
    Oh, that one wasn't going in the WindWalker ... that one was for a different project ... I think I've done 3-4 of these like this?
    It's not that bad when you do most of the prep work yourself.
    And yes, the new MPD intake is bad ass
    San Clemente, Ca
    I got it all cleaned up, was a bitch tool probably 30-40 minutes, that epoxy was really on there and was thick all the way around and chunky where it broke loose from the hull. I used a angle gringer with a 2-3" sanding disc.
    One thing that sucks, when moving the intake i dropped the thing and chipped off a small chunk of the front left corner, the bolt hole is still there is just has a small opening now.. Errr... maybe when jack is welding up my fins he can fill that back in.
    Thats the ticket!!!!!!!!!!!!! Brian's a pro at this! I have seen several pics from him
    So Cal
    Yeah ... I've done it a couple (hundred) times
