Pump goes dry at idle
Results 1 to 3 of 3
    Sep 2013
    Default Pump goes dry at idle
    BBC with a JF pump and at idle it will go dry. This is the only jet I have been aound so is this common or is there something I can do to fix the problem?
    Quote Originally Posted by Sweat View Post
    If your saying the water flow to the engine decreases or stops at idle and there are no "down stream" valves or restrictions (to the engine), your likley facing an internal jet issue
    Sep 2013
    it doesn't do that but the pump makes a noise--like the impeller rubbing the wear ring while they are both dry.
