Cooling issue
Cooling issue
    AAARRRRRGGGGGGG!!!!! Motomatt68's Avatar
    Nov 2009
    Default Bypass cooling system not reading warm on gauge
    I am running a raw water system in my 383. I have this bypass set up.
    Polished Stainless Thermostat Kit For Chevy, 455 Olds
    The temperature sensor is in the intake manifold. The gauge reads cold (below 130 the lowest it reads) if I crimp both the tubes going from the tees where the water pump is normally to the thermostat housing the gauge jumps right up to 190 and stays there. As soon as I let them go it drops back down to below where the gauge reads.
    How do I fix this? Do I have something set up wrong?
    Thanks, Matt.
    Nov 2009
    I will try to draw a picture if this makes no sense...
    Nov 2009
    I solved my problem by adding a gate valve between the tees where the water pump normally goes and the bypass thermostat. I believe that the resistance in the engine water passages was high enough that it allowed water coming from the bypass to flow into the intake manifold just enough to cool the sensor which was near the thermostat.
    By necking down the bypass water it equalized the pressure stopping the back flow.
    I hope this helps someone in the future.
    Matt
    Senior Member BGMAN's Avatar
    you shouldn't need that gate valve there. Something else is wrong. Are you sure you have everything installed correctly? Hoses going to the correct ports? You have that plastic 4 vane valve in there? Thermostat installed correctly? Thermostat has a bypass hole drilled into the side of it?
