water relief valves
Results 1 to 9 of 9
water relief valves
    Senior Member Futs's Avatar
    Orange CA, Big River
    Default water relief valves
    What type and where are you guys getting them? What PSI are you adjusting them to?
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    any hardware store
    18lbs thru the inner cooler on the blower motor 540
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    15 psi. Been running this one for 5 years now. And have it on several different boats.
    McMaster-Carr
    Senior Member kidd bill's Avatar
    Silverton,OR
    Quote Originally Posted by wpmxwb View Post
    McMaster-Carr
    Same one I use also set to 15 lbs. I plumbed mine with a gauge and used air to set the relief pressure on it than hooked the water hoses back up, haven't had any problems since.
    McMaster-Carr
    Same one im using as well, works good, have a couple boats that need one. Just seeing what the latest and greatest was. guess if it works don't fix it,
    Senior Member Jetdream'n's Avatar
    Sep 2009
    Concord, NC
    This is what I've been using set at 15psi
    CP Performance - Water Pressure Relief Valve 1/2" NPT
    Senior Member BGMAN's Avatar
    I have always used the one that Rex, Teague, CP sells. It's smaller than that McMaster one and seems to do the job.
    I use the larger one so it'll release more faster
    Shell Knob, MO
    Right! If you are running a lot of HP, the 1/2" valve can back up pressure. We always recommend and use the 3/4" valves in our systems. .02
