How many different types of steering tubes are used on jets
Results 1 to 11 of 11
    Sep 2014
    Rockford Il
    Default How many different types of steering tubes are used on jets
    Mine is a straight tube with a nut on the inside of the transom an the outside of the transom that doesn't allow much movement. Tom indicated I need a grommet that allows a little bit of flexibility. So the nuts just compress the grommet into the opening ? Then is the tub just supposed to wiggle around on the grommet?
    Sep 2014
    That's how mine is!
    Colfax, Ca
    This is the type I have.
    Hi-Tech Performance : Home Page
Name:	Transom Steeriing Kit 4014.jpg
    Is this real or the "Twilight Zone"?
    Quote Originally Posted by horsepowerjunkie View Post
    A steer tube bushing when properly installed will seal well and give the flex/pivot needed and avoid binding , this is one of our conversions but same concept , note the little fat roll between the nut and the hull
Name:	panther st tube.jpg
    Sep 2014
    Rockford Il
    The grommet I had have if it is grommet does not look like that type.
    Sep 2014
    Rockford Il
    Thats cause yours is weathered and smooshed , time to renew
    Sep 2014
    Rockford Il
    Thanks Tom
    Sep 2014
    Rockford Il
    The tack welds on the little nut on the right were broken , so I had it welded yesterday and didn't realize there was an o-ring in there. Anybody have some specs on it so I go to the local hardware and get something that works?
    Sep 2014
    Rockford Il
    Anyone know the OD of the steering attachment piece that runs through that O ring
    Sep 2014
    Rockford Il
    5/8" ID 11/16" od
