How many hours will a pump handle?
Results 1 to 8 of 8
    Sep 2013
    Default How many hours will a pump handle?
    I've heard that the jet pumps will last forever and was wondering if anyone had an hour estimate on their jet pump??
    We have a Glastron CVX 20 built in 1978 that always been in the extended family, we recently acquired it for testing a new prototype part we are building and we disassembled the Berkeley 12 JE for the first time ever in its life recently , The jet drive has over 1500 recorded hrs of use over 40 years , its been stored remote at a family Lake cabin and used by 3 generations of family members , It was still working well prior to disassembly and looked very good inside , the boat was very consistent in how it worked and operated and was chosen for our testing for that reason Tom
    Oct 2011
    Sandia,Tx. 78383
    Horsepower up ......Longevity down......pretty simple , . ....nothing lasts forever
    http://oathkeepers.org
    Senior Member Mr. Denton's Avatar
    Jun 2014
    Always loved that boat model.
    “Some people spend an entire lifetime wondering if they made a difference in the world. The US military doesn’t have that problem.”
    Using Tapatalk
    Jan 2012
    St. Louis, MO
    X2. A true classic. I intend to have one of these before I'm worm food...
    Shell Knob, MO
    Love those old boats. We just finished restoring one yesterday.
    Sep 2012
    Nice!!
    Quote Originally Posted by Mr. Denton View Post
    Bond ---James Bond As far as life of a pump, that depends on the use and care of the pump, if you want to run it in shallow water and up on the beach cut the life down down by A BUNCH! simple explanation " would you use sandpaper for bearings on your'e crank. Alot of people don't realize that a pump will pull off the bottom in 3 feet of water depending on the build of the pump. If you don't believe me put your'e foot down under the intake at idle. A berkeley pump is designed to flow at least 72 gallons per minute And after work with the pump alot more. So before you go bitching at a builder you might want to think about how you treated the pump in the first place! Or i would recommend stand behind the nozzle. You will get a better idea of the thrust that pump puts out.
