Intake pressure?
Results 1 to 14 of 22
Intake pressure?
    Sep 2012
    Default Intake pressure?
    Round bottom 18' v-hull, any ideas on what would be ideal pump intake pressure or close to it might be? Right now I'm just under 30 lb. top and bottom, thanks.
    May 2014
    What's your rpm ?
    Shoe ?
    Inducer ?
    Loader ?
    All of those are things we need answered be for I could help you pics are worth a thousand words
    Senior Member uniboarder's Avatar
    Dec 2012
    If you are referring to engine cooling water (as well as whatever exhaust water you use) 15psi should be max. Just for comparison the average garden hose pushes 45 to 60psi.
    Sep 2012
    Quote Originally Posted by tbscustoms View Post
    What's your rpm ?
    Shoe ?
    Inducer ?
    Loader ?
    Tapered shoe, 1 1/2. Open loader no inducer, 5900 rpm,.
    Quote Originally Posted by Bobbylisa View Post
    I asked a similar question a year or 3 ago.....could never get an answer other than it varys per hull.
    Are you tapped top and bottom...or just in the center.
    One thing adding the pressure taps did for me is tell me I had too much loader....and not enough shoe.
    Edit....just reread that you are tapped top and bottom...my bad
    May 2014
    How low is the shoe below keel
    Sep 2012
    .040 below, shut down is good, running in the 80's. Loader is .060 above.
    May 2014
    Pressures a little low but set up sounds good what impeller cut are you turning all I could say is put a shim under the shoe and see what it dose just remember that make shut downs on the unsafe side the lower you drop it .... Keep it safe take notes
    Sep 2012
    B cut, aggressor.
    May 2014
    Can you post a pic of your loader
    Sep 2012
    its one from jet boat performance, semi pro open center loader.
    I'd say you're pretty close. I'd bring the loader down to keel line and run it.
    Sep 2012
    Thank,s for the input!!
    Apr 2010
    Rocklin, Calif.
    Default Scooter
    Tell dad..1/8" below keel...shoe and loader, got mine right
