Leaky oil drain hose pulling the motor
Results 1 to 3 of 3
    Sep 2014
    Rockford Il
    Default Leaky oil drain hose pulling the motor
    Since I've been working on the boat and I have the interior out I've been cleaning the bilge but I noticed oil keeps leaking from the back of the pan. there's a hose extension on it that you poke through the drain plug and drain the oil out the back. I believe the hose adapter is dripping and leaking. so if i loosen the motor and disconnect it from the universal joint and don't mess with any settings can I just pull it out fix the oil leak and put it back in or is there an alignment issue? Or what kinds of things do I need to look for or make sure of? Assuming it's lined up correctly now
    Quote Originally Posted by horsepowerjunkie View Post
    That should be easy in a jet boat, if it's working now, it should go right back in with no issues.
    kenny nunez
    Oct 2014
    Kenner, La.
    Default oil leak
    Make sure the pan is not the problem
