Revision troule after exhaust change?
Results 1 to 6 of 6
    Senior Member crf311's Avatar
    Meraux, LA
    Default Revision troule after exhaust change?
    Looking to get some input as to "is my cam too big for my exhaust". Changed exhaust now I have revision issues!
    engine is a BBC gen V 454, 9.5CR, steel heads, cam spec: solid lifter, 249/254 @.050, .615I/.626E lift, 110 lobe sep, 106CL with 4deg adv.
    My motor was built for OT headers and I never had a issue, switched to some lighting headers with no issue, only they didn't last with the salt water down here, no knock on them I just purchased wrong ones for freshwater.
    Picked up a set of KE cast alum headers with bravo tips, made some S bends to go thru the transom, and ended up with revision problems.
    I think I'm going to go with a retrohydr roller cam setup with the following:
    230/[email protected], lift .323/.323, 112 lobe sep, 110 CL.
    What you think? Thanks
    Quote Originally Posted by crf311 View Post
    Likely a combo of the duration @ 50 and lobe center , where does the exiting water actually enter the exaust system relative to the end of the rizer (vs the vertical center line of the manifold ?
    So. Is the cam installed at 106 or 102. 4degrees ahead is 106. If its ahead of that its openi g the exhaust valve too soon. I would install it at 108. Just my .02
    Meraux, LA
    Tom
    the water enters about 2-3 inches behind the end of the riser. It looks like the water entry point is only a few inches below the lowest bend in the mainifolds.
    Meraux, LA
    Quote Originally Posted by tigertooth View Post
    Tiger, That's the spec off the cam card. It has 4 deg. built into it. I's been so long I don't remember how many deg I installed it with. Built it the month before Katrina hit. Thanks for the help.
    Shell Knob, MO
    Make sure the gaskets between the risers and the manifolds are good. Leak there will cause that problem.
