Mounting seats
Results 1 to 3 of 3
Mounting seats
    Apr 2015
    Default Mounting seats
    Any suggestions on how to mount these seats. There is seat box glassed into the boat but I'm not sure how to secure them. I was thinking lag bolts but I was thinking they might rip out fairly easy... Any thoughts?
ID:	753290Click image for larger version.
ID:	753298Click image for larger version.
    Senior Member 82RUNNER's Avatar
    Apr 2009
    KERMAN
    Couple ideas for you. They make a rivnut type of nut for wood/plastics that will bite into that and use whatever fastener size and style you want.
    Or, get a hole saw and knock a hole in the dead center of the holes just big enough that you can reach in and put t-nuts on the underside.
    I've done both
    Senior Member Texgo's Avatar
    South east Texas
    I'm no expert, but this is how I did mine. The hole is so I could get my hand in and put nuts under the mounting plate. I drilled 4 more holes on the outside corners and bolted my seats down. I couldn't get the photo to rotate.
