Another dumb new guy here...
Results 1 to 14 of 20
    Senior Member HEMETDRAGRACER's Avatar
    IE
    Default Another dumb new guy here...
    Ok... might be a really stupid ? but is there anyway to see what impeller my pump has with out a tear down??? and my next ? is what Impeller would be best suited for a 600-700 HP big block? Pump is a berkeley 12JG
    Bakersfield
    assuming that your pump has never been apart, you can read the tag on the suction housing, it should say some shit like 12-J-G-?
    The last letter is your impeller cut when it left Berk.
    IE
    The guy I bought it from said Jet had been gone thru, so hard to say... Ill check it out though... any other way to know?
    Senior Member Ken F's Avatar
    yep, tow it to someone with some knowlege of jets and pull the bowl.
    Ken F
    The liberals are asking us to give Obama time. We agree and think 25 to life would be appropriate.
    Morgan Hill
    Here is my stupid question....Why does it matter? Are you building it, or maybe bought it less motor?
    Run it and find out! Just an out loud idea. Also 450+ HP should have a stainless impeller, as far as which cut, it depends on where the motor makes peak torque/HP...
    GT
    GT
    IE
    Well, reason for asking is Im putting a heavily built 481 BBC in it, it currently has a mild 454 in it, so sounds like im gonna have to have it checked out, or dig in to it myself... The tag on the pump is marked A... can I see the impeller from the intake to see if its stainless or not? Again sorry for the dumb questions... if you wanna know how to make a heavy car run 8s in the quarter,Im the guy... boat stuff... not so much...
    Newton Ks.
    Yes, you can see the impeller from the intake, also from the cleanout.
    On the BACK side of the impeller, is where teh letter marking it is, so can't see from in front (without a many-thousand dollar borescope LOL)
    Only way to be sure is to take the bowl off and measure a few things, because sometimes an impeller gets cut down, but not re-marked.
    Just keep in mind, Jets are very hard to spin high RPM.
    Every once in a while a guy with a "seriously built" motor, turns up to have one built that would scream in front of a 4-speed and a clutch, get's it's arse handed to it by a jet pump and big impeller.
    Try to keep as much low and midrange torque production as possible in the motor build, and it'll work great.
    H.L. Mencken
    IE
    Cool... good info, thanks, the engine is 13.5-1, like I said 481, 454 .125 over, heavily ported 990 heads, big valves, .715 lift solid roller, team G, 1050 Dom, If it needs more balls I will squeeze it as I have alot of nitrous stuff... sounds like I need a ss impeller for sure then... will the Aluminum one break under more power???
    Rancho Cordova. CA
    From what the experts have said in other posts, yes a SS impeller and the better shaft that can handle more power to slide it onto will be needed. Sounds like you got a nice motor that can make some ponies there.
    Morgan Hill
    Quote Originally Posted by HEMETDRAGRACER View Post
    IMHO the biggest problem with an aluminum impeller under extreme conditions is the cavitation, it can literally "eat" the impeller causing it to fail, a stainless is much tougher and can handle a great deal more cavitation and torque...On a centrifugal pump, the faster you spin it the more HP it can absorb, so if it is an "A" impeller (most common) and the stocker turns it say 4800 RPM, and you put in a badass that wants to see say 6000 RPM, the "A" will still be in the hunt, but if its a stock type aluminum, you will probably peel it like an overripe banana....
    GT
    GT
    Hemet as GT said , your definatley past the aluminum (450 to 500 hp) and into the bronze or stainless , Where that motor makes its 600 to 700 HP power the boat and what your going to do with it will help determine the Impeller , re "knowing what Impeller" without actually partially disassembling the jet and looking at/measuring the impeller its pretty tough . Were experimenting with a new bore scope type mini cam we just purchased should be interesting to see if we can see the backsides of the impellers Tom
    IE
    cool... thanks guys for bearing with my dumb questions... like I say this boat stuffs fairly new for me... this is my 7th or 8th boat, but the first one Im really putting serious power to...
    Morgan Hill
    We just picked up the Milwakee version of that badboy, cool tool for sure...I would think the cable is a bit shy though...That'd be cool!
    GT
    GT
    IE
    We just got a bunch of snap on bore scopes at work... hmmmm....
