need PN # for this pop off control ?
Results 1 to 5 of 5
    Atlanta TX
    Default need PN # for this pop off control ?
    Anyone know the part # for this 5 port 3 way solenoid control for my popoff. It leaks when in the neutral & closed position. .......or a # for a rebuild kit ?
    Found this Part# MMA-41PAAP
    so it may be a 4 way, and I'm not certain of spool type ?
Name:	pop off control 2.jpg
    San Diego, CA
    Doubt it leaks. Usually just needs screws tightened. Take off the large nuts on either end. Slide off the coil. Underneath the coil on the body of the valve there are two Phillips head screws. Most likely those are loose. If they are. That is your leak.
    If not here is a link to the thread for this part. http://www.performanceboats.com/jet-...ir-valves.html
    Atlanta TX
    Widowmaker , thanks, mine seems to be leaking out the port marked EB. I will check on tightening screws 1st & if not will order another..........Thanks again
    San Diego, CA
    EB is the exhaust side for port B. Try it without the filters on. I've see those filters cause problems before, especially if it's ever been used in saltwater or Firebird raceway in phoenix.
    Senior Member River Dad's Avatar
    Riverside, CA
    Damn that water is bad stuff.....
