help with this boat?!? got pics inside
    Jul 2015
    Default help with this boat?!? got pics inside
    hey guys new to the boat scene.
    wondering if any one has any idea of what kind of boat this is. not sure if the pics will help. it has a 12jc a pump in it. any info on this pump would be great as well. upgrades/mods, an reliability. guessing its a late 70 early 80s not sure. has ful length stringers in it as well. thsanks for the help!!
ID:	760897   Click image for larger version.
ID:	760905   Click image for larger version.
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    FWIW. The "CFZ" in the HIN identifies this hull as manufactured by "California Homemade Boats".
    The last digits in the HIN appear as "000" which may suggest the manufacturer year was 1980.... but that is an educated guess on my part
    Additional Edit:
    Found this info as well....
    the CFZ hin number is issued by the state of calif. for home made boats and other boats made by individuals. it does not describe a specific manufacturer. this is also a misc. classification by the state for boats that do not have a HIN number and the manufacturer cannot be identified.
    the boat was either made by a home builder (private party) or the manufacturer is unknown.
    hope this helps
    Jul 2015
    Quote Originally Posted by SNiC View Post
    Additional Edit:
    hope this helps
    also saw a GFZ HIN as Gabriel Manufacturing out of Barstow ca. i was not sure if that was a G or C in the HIN. thanks for the help
    how common was it for people to be making their own hulls in the 80's?
    if so whould there be anything i should check hull strength or anything?
    Apr 2011
    Sweet Home Alabama
    Quote Originally Posted by WetRooster View Post
    After looking harder, YES...I believe you may be correct. That appears to be more of a "G" than a "C". I would lean more toward the G and Gabriel Manufacturing...
    As for your other questions.... maybe the Ca veterans can chime in, because I do not know
