Ski tow pics/ideas
Results 1 to 14 of 33
Ski tow pics/ideas
    Default Ski tow pics/ideas
    My current set up has no ski tow. I've always had the regular plyon 2 bolts in the intake, 2 in the bellhousing. But between my brodix heads not having one of the bolt holes a stocker does,and the tall deck block, I don't see that working. I kinda like Sleeper cp stripper pole ski tow idea, looks like it removable too. I dunno, before I drill more holes in the transom, and do a transom mounted deal, I thought I'd bounce it off you guys.
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    is it missing the holes in the rear of the head or on top at the intake??
    get blown or get blown away
    It's on top, I'm pretty sure the tall deck brodix intake I have is missing the same hole.
    Kreg got the 6 ft "stripper pole" delio , out of "land fill boat" complete with tie straps , its got your name on it Tom
    Sep 2008
    sacramento
    heres mine bolts rear of head and bellhousing
    I have a top mount starter, I'm not sure if that would work or not hydro, it's hard to see in the pic. Tom I'll consider the stripper pole, if you can tell me the background on it. Pics are good.lol
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    Default Ski Toe
    HAY, TRY LOOKING AT THE ONE ON WES'S BOAT IT'S KIND OF INTERESTING, IT'S ON PAGE 2, POST 55, ON LOOKING FOR A BADASS BOAT COVER
    Took it away from the Stripper what else ?
    seriously its all there but the "box" in the floor
    Senior Member WES...'s Avatar
    I have one that was on my old Daytona, it mounted on the block at 4 places on the front side, its polished alum, if your interested in an idea like this ill post a pic later
    HOUSE OF FLATS LANDLORD
    Thumbs up
    Thanks, I'd like to see that. Fwiw here is a pic of what I'm working with, pay no attention to the masking tape. I did a little remodel deal for my electrical, and it's not done yet. lol Other than the width of the bellhousing on the lower 2 that's what I got.
    Rancho Cordova. CA
    Here is mine...
    It is a stainless steel piece. As you can see, I have the top mount starter too. Hope this helps ya.
    That would probably do it, I like too keep it simple. The ones I've had in the past had 2 through the intake/head, and 2 through the back/bellhousing. I just don't know at this point if having a tall block will affect something like that fitting? Do the upper 2 bolts go into the heads or the block?
    Rancho Cordova. CA
    2 bolts into the back of the heads, and 2 in the bell housing.
    Wouldn't the 2 into the heads be higher with the tall block? I know my alternator belt was too small(after the tall block) my tt's didn't line up with the holes in the transom anymore, my tt's kissed my valve covers after the tall block. I dunno. Maybe I'm up in the night,again.lol Nice looking boat btw.
