[Question] Help!
Results 1 to 3 of 3
Help!
    Jul 2015
    Default Help!
    I just pulled the Berkley water logs off of my Olds.455...had some exhaust gaskets to replace, right? Well, my starboard manifold is got a crack the size of....well, you know. The Manifold is toast, cracked, major deformation on the the center two cylinder ports.
    I need this problem resolved in 2 weeks as I will/should be on Lake Powell.
    What are my options for bolt on replacements without changing too much else?
    Hardin Marine has these: Log Manifolds - 350-455 Olds - Hardin Marine
    But I cannot find any riser that goes with these.
    Anybody got a good used Berkley water log for the starboard side of a 455 Olds?
    Thanks,
    Kurt
    New Jersey
    Kurt,
    Hardin has the risers too - under the "tailpipes and risers" tab. A little hard to find since it is not grouped with the logs.
    Large Risers 12" x 13" - Hardin Marine
    Other riser options:
    Hardin Marine - Tailpipes & Risers
    Call them if you don't see exactly what you need.
    Doug
    New Jersey
    You could check the parts for sale section for used,
    or check with Tom at Jet Boat Performance - he often has stuff like this laying around.
