njba tech question
Results 1 to 14 of 16
njba tech question
    Default njba tech question
    What grade bolts are required for the loader. I think they need to be 5/16 Black Oxide. Does any of the other underwater hardware need these also like my shoe or ride plate. Thanks hope to make the season opener at Lake Elsinore
    Nor Cal
    Default Grate bolts
    The Rules only state that the bolts must be drilled through, and fastened with nuts (preferably nylocks) inside the boat.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Quote Originally Posted by J. Shelfo Sr. View Post
    Only two have to be drilled through right? 5/16 sounds right to me, not sure if it's a rule but i know from a safety standpoint they should be larger than what they where stock.
    Santa Clarita
    Quote Originally Posted by Sinbad View Post
    What grade bolts are required for the loader. I think they need to be 5/16 Black Oxide. Does any of the other underwater hardware need these also like my shoe or ride plate. Thanks hope to make the season opener at Castaic.
    Castaic?????
    San Diego, CA
    Rule book doesn't say two just says bolts must be thru bolted. Besides I see no reason not to do all four.
    Think about how much force is being applied to that loader at 100mph...... put it this way what do you think would happen if you tried to put your finger in the water at 100mph... it would probably rip your skin off.
    Senior Member blownjet's Avatar
    Winchester
    I WAS TOLD LAST SEASON NOT ENOUGH THREAD SHOWING!! HAD STAINLESS BOLTS WITH NYLOCKS, BROKE A FEW HEADS SO CHANGED TO BLACK OXIDE WITH 1/4'' OF THREAD SHOWING
    Member blownjet417's Avatar
    winchester
    Its Good I Upgraded Too Since I Am Going To Psi Blower So I Can Defend My Championship In Bgj Too.
    It may be IHBA rule but one of them states that the bolts are not to be SS. Also I believe the building code rule of 3 threads showing beyond the nut is what they want to see.
    Cy
    Winchester
    Quote Originally Posted by blownjet417 View Post
    HEY ROBERT, JUST BARELY HAVE THE $$$ FOR THE FIRST RACE LET ALONE A PSI BLOWER
    Precision Craft Marine
    Napa, Ca
    You should bolt through with all 4, and use a grade 8 bolt. Change them once a year, along with the nyloc nuts, and you should be just fine, and legal. Bolts are cheap, Hospitals are expensive.
    Default thanks all
    Thanks for all the help guys. Im am through bolted but there stainless so well have to find some new allen 5/16 x 1 1/2 countersunk bolts. Joe any chance you carry these. The boat is Das Boot Rathke's old ride. Again thanks.
    Napa, Ca
    Yes ,I do have them.
    Default black oxide bolts
    Thru drill the loader bolts, take out the thread on the intake. Unless you change your hardware every time you run the boat it will rust , and seize the threads.
    Senior Member bp298's Avatar
    LHC
    hey bill, good to hear you're going to run that thing again.
    5/16 black oxide machine screws are preferred over stainless because of the load. the oxide screws will stretch, while stainless doesn't stretch too well, and just break from fatigue. routinely check to see if any of the screws have loosened due to stretch, replace 'em. i replace mine a couple times a year...
