dominator pump
Results 1 to 5 of 5
dominator pump
    Junior Member 78mantra's Avatar
    Jul 2012
    Default dominator pump
    Dominator pump aa aggressor been sitting for years just finished putting my engine in yesterday and when trying to start the engine and while idling it makes a growling sound coming from around the pump any ideas on what this might be
    Junior Member Critical Mass's Avatar
    Jul 2010
    Los Alamos, NM
    It sounds like you started it out of water.
    Jul 2012
    Jus for a few sec until I heard it
    May 2014
    Kinda a normal noise when tuning a pump out of the water
    Is a big no no if you like your pump at all pull the drive shaft to run and tune the boat
    Quote Originally Posted by 78mantra View Post
    Setting for a long time might give pause for some concern over bearing issues (rust or corrosion forming) however some "machine noise", driveline rattle is a common malady in jets and is made worse with worn splines , solid engine mounts , alloy hulls and heavy impellers , lumpy cams etc , typically this noise dissipates with a slight impeller load (RPM increase over idle )
