Pop off piston stuck in pump
Results 1 to 14 of 14
    Atlanta TX
    Default Pop off piston stuck in pump
    Anyone ever had pop off piston hang up ? Mine has worked flawless for 2 years. Now it's stuck. I took bowl & impeller off & disassembled the valve itself , but the piston is hung up. I wacked it pretty good with a piece of hickory & sledge hammer but it aint gonna budge. Gonna try and make a puller tomorrow. Don't know what else to do ?
    ......................Why is It so hard to type on here ? Happens every time I get on PB , anwere else is fne......see !
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    There must be something that got in there with it to hang it up. I have seen a hair make it between the float needle and seat in a carb. And cause it to sieze.
    QE 439 Twin Turbo
    149 Tsunami BGJ 153 MPH
    Dec 2014
    So Bay CA
    Default Stuck
    Quote Originally Posted by cpjet View Post
    disassembled the valve itself !
    August 2, 2015
    Hello People
    What make is the valve
    Willis
    149 Tsunami - 153 MPH @ 6.93
    Atlanta TX
    The one they called "big mouth"................miersh I think ?
    Feb 2015
    Can you apply heat to it and then hit it?
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Atlanta TX
    Yes , mine has a black neoprene type so I assume its the delron piston. Taking my outboard to the lake, I'll try & take a pic of popoff when I get back....Thanks
    Atlanta TX
    Wonder if the delron piston can handle much heat applied ? Still planning on making plate for a puller but worried it'll pull threads out of center off the piston.
    Atlanta TX
    valve pics
ID:	771305   Click image for larger version.
ID:	771313   Click image for larger version.
    New Port Richey, FL
    I would put some penetrant around the edge and let it soak. Make a flat plate that you can bolt to the top of the piston with the 2 bolts holes already there and attach a slide hammer.
    QE 439 Twin Turbo
    Feb 2015
    River Boat,,,, Probably has sand caked around the seal? when was the last time the Valve was exercised .
    Atlanta TX
    Valve worked the previous weekend. Ron , I soaked it overnite & then wacked it with sledge , I'll soak it again & see if Piazza has a slide hammer I can use.
    Atlanta TX
    got it out.
ID:	771793   Click image for larger version.
    Sacramento area
    What caused it to stick?
    Atlanta TX
    Piston grew a little bit .
