Cavitation???????
Results 1 to 12 of 12
Cavitation???????
    Lexington, KY
    Question Cavitation???????
    Ok first new thread from me in a few months. And here's a real newbie question for y'all. How do you know if the pump is cavitating? I think mine did it once or twice on me last season out of the hole, but im not sure. So here's what it did; i pressed the gas, and the boat went nowhere, waited a few seconds pressed again, still nothing. So i killed the engine, sat there for a few minutes, talked to another boater that recognized my boat from the last time it was on the river before i owned it, then started it back up, pressed the gas and it actually moved this time. Always a good thing when there are other boats around.
    Also, i still have a little bit of popping at the very highest rpm range that my boat turns. I want to think that it's the pump cause im hoping that it's not the engine. Does cavitation do that (popping)? Cause it doesn't do it constantly like i would think it would if it were the engine, only when i give it the final little bit of gas to go full throttle. Full throttle for me is about 4500 rpm, if i remember correctly, been a long cold winter.
    Oh and i know WHAT cavitation is, just not how to tell when the pump is actually cavitating. So please no long definitions of cavitation, that has been covered on more than one occasion on the site, and has pretty much been beat to death.
    Thanks guys.
    HJ
    El Cajon, CA.
    I knew my boats pump was cavitating when the RPM's went from 5800 to 6200ish.
    Your pump was fouled, or air locked, it happens. Have you ever checked your total timing advance? If not you should check it, you may not be reaching the max advance. Also check the carbon button in your distributor cap, make sure it's not going away on you.
    Santa Clarita
    Did it do this just after putting the boat in the water?? If so you had air trapped in the pump.
    Lexington, KY
    Yes i did finally check it, and got everything set right where it should be (using a good timing light that i borrowed from an engine builder), i can't remember where that is anymore, but im sure it's posted somewhere on these forums so i could find it with a bit of research. The dizzy cap and rotor were brand new and clean, no carbon tracks that i saw.
    No it was after running for about 3 miles, coming down to an idle, turning around and then trying to go back the other way.
    I'm just trying to get some ideas before i put it back in the water in a couple months, so i know if i need to fix anything, or do anything.
    Thanks guys.
    HJ
    I think you saw two different problems at the same time! #1 pump not being loaded and trying to blow air! #2 engine reaching max rpm for its design. If the pump finally loaded and you are seeing 4500 rpm at wot then the pop would be either a timing issue or valve springs with no or little seat pressure left (valve float). Getting a pump fully loaded is a jet boat racers first concern, it will make the difference between a good pass and a bad one! IMLAO M
    Senior Member rorybsst's Avatar
    if your engine is popping at WOT it cold mean ur engine is running to lean. and that popping that your hearing is a lean pop.
    Newton Ks.
    I'm with ol guy in my suspicion of valve float "at the very highest rpm range that my boat turns".
    What is that RPM and what is the valve-train setup?
    My stock GM/Hardin setup would float @ 6-grand (did it cavitating hard in a turn trying to avoid a damn jet-ski once (ONCE)), current setup, not a chance, going to take a LOT higher.
    H.L. Mencken
    Lexington, KY
    I've probably been told before but i just don't remember. What is valve float?? And how can it be fixed?? I think it was 4500 rpm, stock valve-train, stock truck heads, stock 427 tall deck.
    HJ
    [email protected]
    Ohio
    Valve float is when the springs aren't strong enough to close the valves at rpm. With stock springs and if they are old, this could cause valve float and that could be your popping. The fix is new or stronger springs. Moroso makes a tool that you can check the seat presure with the heads on the engine. Years ago I found out what valve float was when my 289 had a miss at 4400. Wasn't pretty after it dropped a valve.
    Tim
    East Side
    The pump won't cause a popping noise. I agree, valve float or a lean condition.
    Senior Member kdub's Avatar
    Houston
    valve float at max rpm wont cause the boat not to move off idle either. If you have a leaky packing or cleanout cover o-ring on the pump it can suck air, also could have picked up some trash in the pump on your three mile run, lodged in a vane on the impeller or bowl.
