Nitrous Purge
Results 1 to 14 of 18
Nitrous Purge
    031 RIVER4FUN's Avatar
    Default Nitrous Purge
    So, it's 108 at the river and my bottle pressure is about 1100 with the boat in the shop. The Edlebrock purge solenoid won't open with that kind of pressure. Of course the nitrous solenoids won't open either. Is there a better purge system out there that will open with that kind of pressure? I've been in situations where the nitrous would'nt hit because of pressure build up while on the holding rope.
    Sep 2014
    I run a regulator straight off the bottle so that the pressure feeding the system is always where I set it unless the bottle pressure is lower than pressure set on the reg. Then I tune with the reg to up a bit of pressure or lower it depending on what what the tune needs/wants.
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    Well, Rich a cold wet towel helps a lot, and use a solenoid with a big magnet for the purge.
    San Diego, CA
    Quote Originally Posted by RIVER4FUN View Post
    1100 lbs shouldn't be a problem with solenoids. Otherwise a wet towel or find another way to cool the bottle down.
    If you are having a really big problem with it. Check out this Pressure Pro Nitrous Regulator they sell two version one for 125hp and another for 500hp kits.
    Boat 405.
    Thanks Kjell. That will work
    Make sure the bottle knob valve is open this Regatta trip!! LOL J/K!
    The problem was too much bottle pressure and the diverter pump quit! We're ready
    Mohave Valley/Quartzsite
    I agree Kjell!! I've scene mine at 1100 all day long and open and my solenoids are ancient!!! Also, I believe if you increase the voltage to operate the solenoids that helps!!! I run mine thru an accuvolt which has a constant 14 volts delivered to them.. Rich, I started leaving the nitrous bottle off until I'm getting ready to run.. I'm to afraid of the damn things leaking and blowing the chit off the top of the motor.. Mike DeClark gave me the ahhhhh moment.. After he told me that I even purge the line when going to the pits!! Guess I'm scared!!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    San Diego, CA
    Quote Originally Posted by stix818 View Post
    For sure Vince, I don't open my bottle until the motor is running and lights are flashing yellow, then I close the valve and purge the pressure in the lines before I turn the motor off coming into the out ramp
    Boat 405.
    Senior Member bp298's Avatar
    LHC
    x2. whenever I run the stuff...
    Senior Member PE 340's Avatar
    Aug 2013
    LHC,AZ
    x2. whenever I CHEAT...
    Fixed it for Ya
    LHC
    Quote Originally Posted by PE 340 View Post
    Fixed it for Ya
    how is nitrous in a bracket class cheatin?????
    Senior Member bc18's Avatar
    Make sure to change your water separator
    I always used a wet towel and it was fine.
