mini starter 460 ford
Results 1 to 3 of 3
    Jul 2015
    Default mini starter 460 ford
    0 can anyboy tellme how to wire a min sttarter o my 460 ford jet boat I have a unilite distributor . I orginaly had 4 wires main battey cable and large guage red wire go together on the batt terminal white wire to "S" terminal and orange wire to " R" terminal. now only 2 terminals. where do these wires go now help.
    Buy a diode from radio shack and tap into the white wire with momentary current flowing to the orange wire during the crank ( orange goes back to the coil or ballast resistor, 12v crank circuit) The idea is to give a 12v "boost" to the ignition during the engine cranking , your white, yellow or white with a trace is typically your starter S wire
    Junior Member Thunderfoot's Avatar
    Sep 2011
    Boise, Idaho
    Default Re-use old starter solenoid
    I've always done it this way re-using the old starter solenoid as large relay... so your S and R wires stay attached where they were.
Name:	ford late starter wire.jpg
