one carb or two?
Results 1 to 7 of 7
one carb or two?
    Member rogers tr's Avatar
    Default one carb or two?
    im building a 540 and was wondering what you guys think should i run a dart single w dominator or dart tunnel ram with two its hard to tell by the pics and what ive seen its kinda 50 50 just like to know what people think im leanin towards two with tunnel ram thanks
    i got skiillllzzzz.... fast76rogers's Avatar
    clearlake ca
    Default carb!
    i run a single dom. easy to tune and less fuel used.it dynoed at over 800hp with a 1050.
    There's rules about this stuff. Tunnel ram requires 2 carbs and Dominators are prefered. A single carb can only be mounted on regular manifold, never a tunnel ram. A single carb on a tunnel ram is just wrong. Ask anyone, they'll tell you.
    JK, go with your preferance
    Senior Member Futs's Avatar
    Orange CA, Big River
    It depends on what your application is. If your combo is built around a single or doubles. I run 2 dominators and Toddnjuzz runs a single domi and we are like a few HP apart from the dyno sheets. Mine was built to make peek @ 6200 and I think todd is right around 6500. Its all in the "combo" Just don't throw parts together, do your homework and get a package that works together.
    Two engines built "correctly", the two carbs on the TR will make more power over a single four. Not to say you can't make tons of power wit one carb, it's been done and proven. Just saying ultimately, two carbs will make more power. Remember, though, you're asking for more headaches...more expensive, more difficult to tune, linkage issues, plumbing, scop mounting, etc. Sometimes simple is worth a few HP. Just depends on your goals. Also, there's nothing that says Dominators are always the best choice for two fours on a TR. Plenty of good running 4150 set ups out there.
    Quote Originally Posted by fast76rogers View Post
    X2
    Always Have Hope
    Bakersfield
    Just buy a good single plane intake and put a 1250 Dominator on it you douchebag.
