Between stringer throttle
Results 1 to 10 of 10
    Renegade jet tunneljet's Avatar
    Shorewood Il
    Default Between stringer throttle
    I was wondering if anyone knew where I could get a foot throttle setup that is on a shaft between the two stringers? I know Toddnjuzz has one I saw in a pic but my computer skills aint the best so when I tried post it here it did not work.
    Do you want it between the stringers, or down in the center pod? Mines mounted on aluminum brackets between the tunnels.
    Shorewood Il
    I saw the pic of your setup and that is nice also. How do you mount it without going through the sides of the center pod?
    there is no getting around that, it has counter sunk stainless fasteners, embedded in sealant, such as silicone or sea-going epoxy
    Shorewood Il
    Cool, I might try that. I hate having my knee up above my elbow.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Quote Originally Posted by tunneljet View Post
    I'm not a big fan of drilling holes through the boat either. With my tanks i glassed a peice of wood to the side of the boat, before i did that i set in these stud things i got from lowes. They are basically a stud but with a washer welded on one end. That end buts up against the hull and into the wood. Then i took my tank straps, slipped them onto the stud and put a nut on them. Dont see why you couldnt do somthing simular there. Show some pics, i'm sure there's some way to get around drilling extra holes in your hull.
    El Cajon, CA.
    My tunnel is the same way.
    easy to build give me call and I well talk you thru it. the champ.
    Senior Member mcderns's Avatar
    Chicago
    Thats cause your too tall and lanky!
    19' Eliminator Daytona
    Instagram: www.instagram.com/mcderns
    Like us on Facebook!!!http://www.facebook.com/pages/Bad-Ap...g/317001948977
    Senior Member CHEVY JET's Avatar
    St. Charles, IL
    I Have The Perfect Solution.... Lets Trade Boats, My Leg Is Strait Out. Lol
