Autometer pedestal mount bracket
Results 1 to 6 of 6
    Feb 2015
    Default Autometer pedestal mount bracket
    Need to know the distance between the two holes and Dia of bolt to use on the Autometer 5" Tach pedestal column mount I have one on order but need it sooner to have it drilled and tapped. Thanks
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Quote Originally Posted by leadslinger View Post
    August 29, 2015
    Hello People
    Lead
    All manufacturers have specifications sheets on their products and the information is easily found on their website.
    You will find all the info on this gauge there.
    Willis
    149 BGJ 156.74 MPH @ 1000'
    Feb 2015
    Quote Originally Posted by willis View Post
    August 29, 2015
    Hello People
    Lead
    Willis
    Hey Thanks ,Sheet doesnt show spec size of base and mounting only says use hose clamp, UH yeah hose clamp I'm not going to **** this.
    So back to my question anyone knows the size of the mounting base of the pedestal at least the length.
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    I would call Tech at Autometer.
    Senior Member liquidator559's Avatar
    Clovis Ca,
    the distance between the holes are 3/4-13/16 . one of the holes are op-longed so either # will work . the hole size is 7/32
Name:	tach mount 001.jpg
ID:	787169   Click image for larger version.
Name:	Tach mount 012.jpg
ID:	787177   Click image for larger version.
Name:	tach mount 006.jpg
ID:	787185   Click image for larger version.
Name:	tach mount 007.jpg
    Feb 2015
    Quote Originally Posted by liquidator559 View Post
    Thank you Liquidator very much your the man of the hour,,,,
