guages and wiring in the jet
Results 1 to 14 of 26
    Charlotte, NC.
    Default guages and wiring in the jet
    So i re-ran all my wiring in the boat. It's all done except i did not replace a couple of hoses and thats next on the list..
    I have one vacume hose one water pressure hose for speedo and one copy tube for a manual oil pressure. I want to scrap the copper tube as it has some damage and is leaking.. I was thinking of replacing it with rubber but wasnt sure..
    I was thinking of this.
    http://shopping.rexmar.com/Merchant2...de=AMmarSender
    or is the copper better.. Im just having a hard time finding copper for this..
    i would assume the other two tubes should be GTG with this.
    Also do i need to charge the hoses with fluid or do they just work on the air pressure.. Stupid question im sure..
    High Rock Lake, N.C.
    Looks like they will work. Just make sure to secure the oil line where vibrations and rubbing will not puncture it. Maybe run it through some wire loom.
    Charlotte, NC.
    Quote Originally Posted by GasGuzzler View Post
    Good thought..
    Kingman/Golden Vly, Az
    whyever would u want to run a line from ur manual oil pressure gage all the way back to ur motor???...if whatever line u use breaks, ur gonna dump 8-10 qts of oil before u can shut it off!...IMO a very bad idea...mount the gage on the motor so u can see it when u want to check it...also...u can mount the vac gage there too...K.I.S.S. ....alot less trouble for urself
    just my .02 cents
    FastRAt
    Morgan Hill
    I agree with not running the line all the way to the dash, how about running the mechanical gauge, but with an isolation transducer like you would see for mechanical fuel pressure gauges? That way if shit were to happen it wouldn't be oil...
    Just a wild, out loud thought!
    Here is the fuel gauge isolator, never saw one for oil but???
    http://store.summitracing.com/largei...g=atm-5813.jpg
    GT
    GT
    Senior Member n8dawg's Avatar
    Santa Paula
    I had stainless braided line on mine. I wouldn't trust anything else.
    Quote Originally Posted by n8dawg View Post
    stainless braided line I wouldn't trust anything else.
    x2
    #55
    Senior Member OUTLAW HALLETT's Avatar
    SHASTA LAKE CA.
    i use to run one of the clear plastic lines , and it just got brittle and pumped a shit load of oil into the bottom of the boat ,i have now ran a nitrous steel braided line from the block clear up to the gauge in the dash , well worth the money in my opinion, ill never have to worry about it again, a nitrous line comes complete with the end, and are fairly cheep,
    Wouldn't an electrical gauge and sending unit be easier/cheaper?????
    Morgan Hill
    Yes.
    GT
    Santa Paula
    http://www.speedwaymotors.com/BRAIDE...-KIT,4147.html
    I wouldn't go halfass on this. Put something good in.
    Rancho Cordova. CA
    If you do run the mechanical guage, be sure to bleed the air out of the line going to the guage or you may get false readings.
    Default 1/8th copper
    I've been using 1/8th inch copper for oil pressure for decades. Never had one fail. I wouldn't use clear plastic on my lawnmower. An electric gauge will be easier to accommodate to the dash. A "T" at the outlet, or use another pressure port, and a mechanical gauge back by the engine turned so it can be seen from the driver's seat. The mechanical gauge is for insurance to verify the electric is accurate. Once again, I have no idea WHERE you are, so the spool of 1/8th copper I have may or may not be in your backyard and 10-14' of it free to you. C'mon guys, list your hometown or area. Not all of us that could/may help you know where you're at.......Ray
    LOUD BOATS SAVE LIVES
    Charlotte, NC.
    All great responces.. let me try to resond...
    Electrical gauge: Yes great idea i had thought of it but really wanted at least a back up manual one just in case... call me paranoid. And when i re-ran the eletrcial wires i also included one for an eletric oil pressure guage... just in case.
    Braided steel Line: AWESOME thats exactly what i was looking for just didnt really know it yet. That works 1000 times better than plastic hosing.
    Secondary manual Guage on the engine: If you have any ideas how i can mount one so i can read it with out having to stand up and crawl in the engine compartment then thats a definate possibility.
    Location: Sorry i thought it was listed. I added it. I live in Charlotte NC. I was wondering why people kept asking me that. :-)
