Crab issue solved - C&J Engineering
Results 1 to 7 of 7
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Carb issue solved - C&J Engineering
    September 17, 2015
    Hello People
    Another master piece from C & J Engineering.
    My 1998 Howard 19 footer has been grounded for several years. I decided to run the engine to circulate the oil and heat it up to dry out the moisture, to my surprise, there was more stuff than I could get out with one flushing of the fuel system.
    I sent my carbs to John and he worked his magic to solve my carb issues.
    I am sure that there are people who would say how come I didn’t restore them myself?
    The carbs have been flowed to my engine specs and it’s just simpler to have the pro do it, he has all those parts that needed replacing at his finger tips and the history of what he did to the to make them work flawlessly every acceleration and cruising part throttle.
    Willis
Name:	850 CFM C&J Sept 2015.jpg
    149 BGJ 156.74 MPH @ 1000'
    Promoting pollution Smog Pump's Avatar
    Sep 2010
    Pumpkin Center, CA
    Glad you got the CRABS taken care of. THEY can really be the shits, let me tell you!
    It don't have to be fast to have fun............
    Sacramento area
    Default Crab issue?
    If your carbs had crab issues and they fixed that? THEY ARE GOOD!
    Gardena, CA
    Default Boat Carbs
    Quote Originally Posted by Smog Pump View Post
    September 18, 2015
    Hello People
    Smog
    How did C & J help you, what was the issue on your boat
    Willis
    Sep 2010
    Pumpkin Center, CA
    Hello Willis.
    They haven't helped me yet. I am allergic to CRAB, and CRABS, so I avoid it. However, I'm sure if I ever made a mistake and went into anaphylactic shock after ingesting some possibly they COULD help me if they were medically trained I guess??
    Thanks for asking.
    Phil
    Gardena, CA
    Hello Willis.
    CRAB
    September 18, 2015
    Hello People
    Phil
    Thanks for pointing out the sp on carbs
    Willis
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    Cant say enough about how good mine run, highly recommend them.
